楼主: confiope
[原创] 求助大侠:同步BOOST,PMOS管隔离环的画法
发表于 2013-11-21 20:05:59 | 显示全部楼层
回复 20# hszgl
还请您细心找出您说的错误具体地方,谢谢
发表于 2013-11-21 20:07:57 | 显示全部楼层
回复 20# hszgl
   我没发现啊,请帮我找出来,谢谢
发表于 2013-11-21 20:26:51 | 显示全部楼层
unfortunately ,i do(did) not have deeply  research(ed)  on boost,but i know (the) how to do it actually,and you('re) still puzzled by (the) substrate of pmos。( i only have to say )(没见过这种说法):ha ha, and u (should) keep the substrate of pmos always high
i (was) also puzzled by how relieved(这个词放这感觉好诡异) your boss  let you do(design) a boost converter without any guider
我去,我可以去当英语老师了。。。
发表于 2013-11-21 20:34:05 | 显示全部楼层
回复 23# hszgl
   unfortunately ,i do(did) not have deeply  research(ed)  on boost,but i know (the) how to do it actually,对于上面这句话,首先时态是错误的,应该过去式。但是have research on 这里动词是have,不应该have deeply  research(ed)  on。 所以正确的是我的原话。
but i know (the) how to do it actually这个你要加个the?你解释下。
发表于 2013-11-21 20:36:51 | 显示全部楼层
回复 23# hszgl
   其他基本可以采纳
发表于 2013-11-21 20:37:44 | 显示全部楼层
回复 24# jiang_shuguo
    这个 “the”是你加的。你回去看看。
    have这里我没写清楚,应该是两种情况,did not have sth 或者 have not done sth...
发表于 2013-11-21 20:38:42 | 显示全部楼层
回复 23# hszgl
   i was also puzzled by how relieved your boss is  let you design a boost converter without any guide 这样就好了少了个is
发表于 2013-11-21 20:39:52 | 显示全部楼层
回复 27# jiang_shuguo
    还有如果research作名词,不能用deeply(副词)修饰。
发表于 2013-11-21 20:43:24 | 显示全部楼层
回复 28# hszgl
   是的,受教。我现在的语法几乎为零了!
发表于 2013-11-21 20:45:22 | 显示全部楼层
回复 29# jiang_shuguo
    照理说工作中应该会用的更多才对额。。。你在大唐微?
GMT+8, 2025-12-28 12:30 , Processed in 0.017349 second(s), 3 queries , Gzip On, Redis On.
