查看: 2499|回复: 3
[求助] 大家帮我看看这个100进制计数器VHDL的设计有没有问题
发表于 2013-11-15 20:17:04 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity cnt100 is
   port(clk:in std_logic;           q ut std_logic_vector(7 downto 0);
           c: out std_logic);
end cnt100;
architecture one of cnt100 is
signal qa:std_logic_vector(3 downto 0);
signal qb:std_logic_vector(3 downto 0);
signal cin:std_logic;
begin
   q(3 downto 0)<=qa;
q(7 downto 4)<=qb;
   process(clk)
begin
   if clk'event and clk='1' then
   if qa=9 then qa<="0000";cin<='1';
else qa<=qa+1;cin<='0';
end if;
end if;
end process;
process(clk,cin)
begin
     if (qb=9 and qa=9) then qb<="0000";c<='1';
  else c<='0';
  end if;
  if cin='1' then qb<=qb+1;
  end if;
end if;
end process;
end one;
发表于 2013-11-16 22:50:48 | 显示全部楼层
仿真一下就可以的
发表于 2014-3-31 10:51:28 | 显示全部楼层
路过,不懂
发表于 2014-4-4 23:05:06 | 显示全部楼层
通过波形仿真,分分钟就可以得出结果
GMT+8, 2025-12-21 00:22 , Processed in 0.020153 second(s), 7 queries , Gzip On, Redis On.
