查看: 2282|回复: 2
[求助] 紧急求助,Modelsim仿真时候遇到的奇怪问题,现象简单,但是没法解释
发表于 2013-10-31 15:42:06 | 显示全部楼层 |阅读模式
本人在仿真VHDL代码时,遇到了问题,希望高手解答啊!!!谢谢
以下时在仿真时候遇到的问题和现象,请耐心看完,如果您没有耐心,可以直接跳到最后的一段话和附图。
1. 粉色框所示,Wr_rd_cnt应该在Ddr_dline_cnt拉高一个cycle后才会+1,结果如图所示,在拉高的同时就已经+1了。这段程序如下:
Process(Rst,Clk)
begin
if Rst = '1' then
Wr_rd_cnt <= (Others=>'0');
elsif rising_edge(Clk) then
if State_start = '1' then
elsif
Ddr_dline_we = '1' or Ddr_dline_rd = '1' then
Wr_rd_cnt <= Wr_rd_cnt + 1;
end if;
end if;
end Process;
同样的在Ddr_dline_rd的驱动下,Wr_rd_cnt是没有问题的(见第二个小图)。
2. 蓝色框所示,Ddr_dline_data[ 63:0]应该在一个cycle以后赋给Ping_0_din_a,结果同样是没有延迟。代码如下,
Process(Rst,Clk)
begin
if Rst = '1' then
Ping_0_din_a <= (Others=>'0');
Ping_1_din_a <= (Others=>'0');
Ping_2_din_a <= (Others=>'0');
Ping_3_din_a <= (Others=>'0');
Pang_0_din_a <= (Others=>'0');
Pang_1_din_a <= (Others=>'0');
Pang_2_din_a <= (Others=>'0');
Pang_3_din_a <= (Others=>'0');
if Ping_ram_en = '1' then
         Ping_0_din_a <= Ddr_dline_wdata(63 downto 0);
Ping_1_din_a <= Ddr_dline_wdata(127 downto 64);
Ping_2_din_a <= Ddr_dline_wdata(191 downto 128);
Ping_3_din_a <= Ddr_dline_wdata(255 downto 192);
elsif Pang_ram_en = '1' then
Pang_0_din_a <= Ddr_dline_wdata(63 downto 0);
Pang_1_din_a <= Ddr_dline_wdata(127 downto 64);
Pang_2_din_a <= Ddr_dline_wdata(191 downto 128);
Pang_3_din_a <= Ddr_dline_wdata(255 downto 192);
else
end if;
end if;
end Process;
3. 而另一个信号Ping_1_we_a可以正确传递,比Ddr_dline_we延迟一个始终周期,如上图绿色框所示。代码如下。
Dpram_we
<= "0001" when (Ddr_dline_we = '1' and Range_write = '1' and Wr_rd_cnt(6 downto 5) = "00") else
"0010" when (Ddr_dline_we = '1' and Range_write = '1' and Wr_rd_cnt(6 downto 5) = "01") else
"0100" when (Ddr_dline_we = '1' and Range_write = '1' and Wr_rd_cnt(6 downto 5) = "10") else
"1000" when (Ddr_dline_we = '1' and Range_write = '1' and Wr_rd_cnt(6 downto 5) = "11") else
"1111" when (Ddr_dline_we = '1' and Azimuth_write = '1') else
"0000";
Process(Rst,Clk)
begin
if Rst = '1' then
Ping_0_we_a_i <= "0";
Ping_1_we_a_i <= "0";
Ping_2_we_a_i <= "0";
Ping_3_we_a_i <= "0";
Pang_0_we_a_i <= "0";
Pang_1_we_a_i <= "0";
Pang_2_we_a_i <= "0";
Pang_3_we_a_i <= "0";
         Ping_0_we_a_i <= Dpram_we(0 downto 0);
Ping_1_we_a_i <= Dpram_we(1 downto 1);
Ping_2_we_a_i <= Dpram_we(2 downto 2);
Ping_3_we_a_i <= Dpram_we(3 downto 3);
Pang_0_we_a_i <= Dpram_we(0 downto 0);
Pang_1_we_a_i <= Dpram_we(1 downto 1);
Pang_2_we_a_i <= Dpram_we(2 downto 2);
Pang_3_we_a_i <= Dpram_we(3 downto 3);
else
end if;
end if;
end Process;
Ping_0_we_a <= Ping_0_we_a_i;
4. 其中的Ddr_dline_weDdr_dline_data[ 255:0]为模块端口输入,信号由另一个模块中通过读Fifo的数据产生。
具体程序见附件RAM_CTRL_PORT_A.vhdRD_DDR.vhd。两个模块各自仿真时没有错误,夹杂别的模块一起仿真时候就会产生错误,并且每次都是这个位置。驱动时钟也是同一个。
5. 我在RAM_CTRL_PORT_A.vhd中将输入信号Ddr_dline_we和Ddr_dline_wdata用时钟打了一拍,仿真出来结果却没有相应的延迟一个Cycle,Ddr_dline_we和Ddr_dline_we_d完全一致,Ddr_dline_wdata和Ddr_dline_wdata_d也完全一致。
发表于 2013-11-1 14:21:40 | 显示全部楼层
回应第一个问题:“Wr_rd_cnt应该在Ddr_dline_we拉高一个cycle后才会+1“  你这个认识好像不对吧。在Ddr_dline_we拉高后的第一个时钟上升沿,Wr_rd_cnt+1,而不一定是一个cycle。由图可见,你的Ddr_dline_we和Wr_rd_cnt应该不是同一个时钟域。建议你把信号Ddr_dline_we用这个时钟打一拍,然后再用同一个时钟域的信号。
发表于 2014-1-2 15:40:33 | 显示全部楼层
没有看懂,呵呵。
GMT+8, 2025-12-17 18:54 , Processed in 2.174119 second(s), 9 queries , Gzip On, Redis On.
