查看: 7586|回复: 2
[招聘] MARVELL 最新对外招聘职位,有兴趣者请投递简历。
发表于 2013-10-23 13:02:18 | 显示全部楼层 |阅读模式
欢迎投递简历: edwar2046@gmail.com
请在邮件名上写明相应应聘职位,谢谢!
1、Job Title: Physical Design Engineer
Department: COT PD-SH -MTSL
Job Description:
Physical Design Engineer will support physical design requirement of different business unit of Mavell, the main responsibility is:
physical implementation, including floorplan, power routing, placement, clock tree synthesis, timing closure, routing, si fixing, drc fixing, dfm ...etc
physical verification: including low power check, timing analysis, timing eco, xtalk analysis, power analysis, ESD analysis, EM analysis, drc check, lvs check, ant check, erc check ...etc
tapeout: timing signoff, power signoff, design tapeout... etc
Qualification:
BS/MS in EE/CS required.
Some knowledge and some experience on process, parameters, synthesis, timing analysis, placement, routing, CTS, SI, power calculation, custom layout, timing analysis and DRC/LVS.
Familiar with Cadence, Synopsys, Mentor, Magma, Apache… EDA tools and design flow;
Familiar with Verilog HDL, Spice
Good programming skill. Capable of writing Tcl or Perl.
Self-motivated team worker, good verbal and written communication skills in English
2、Software Developer for Linux BSP and Android
Department: AP Systems Engineering
Description:
In this position, you will be working with the platform architects, technical leaders and other developers to contribute to embedded Linux BSP/Android and platform software development. You will be responsible for the detailed development specifications (example, component Low Level Design) and unit test plans, participating in BSP software implementation for handheld and/or cellular platforms and work with the validation team to ensure the product is thoroughly tested and meets established release criteria.
The candidate is expected to have below extra qualifications:
-Master in Electronic Engineering or Computer Science major or with relevant experience.
-ARM or embedded experiences
-Strong programming and debugging skills in C/C++
-Linux Kernel/Driver development experiences
-Hardware debugging experience or board design experience is a plus
-Multimedia framework GStreamer, OpenMAX or DirectShow is a plus
-Fluent communication in both Mandarin and English is a plus.
3、Senior Camera Software Engineer
Description:
In this position, you will be involved in the Camera related software development for Tablet platform. Responsibilities include Camera driver/middleware/application development, performance optimization and system integration, etc.
Qualification:
- 3 years+ camera related development/support experience.
- Familiar with camera sensor, ISP knowledge.
- Solid experience on Windows mobile and/or Android platform driver development.
- Strong in C and/or C++ coding expertise.
- Solid communications skills, Good team work spirit
- Camera sub-system architecture knowledge, middleware and application development experiences on Windows and/or Android
- Good knowledge base in Image Processing, e.g. Auto White-Balance, Auto Exposure, Auto Focus, Digital Image Stabilization and Face Detection/Recognition, etc
4、Senior Audio Software Engineer
This position is for the embedded Audio development at Marvell Shanghai site. Marvell is developing new generation application and communication processors with rich audio feature support both for SW and HW-based solution. He/she will join the company's effort in delivering the audio libraries required to create software product for the next generation application and communication processors, and participate in testing, developing, optimizing and/or porting the audio codes, framework and software solutions.
-Excellent algorithm background about common DSP and multimedia functions/applications
- Solid knowledge/experience on the C/C++ and Assembly programming languages
-Excellent understanding of the embedded system architecture, familiar with the embedded OS, such as WinCE/WinMobile, Linux, Nucleus RTOS.
-Excellent hands-on skill on software programming, optimization, testing and debugging
-Experience on audio codec such as MP3, AAC LC/LTP, HE-AAC, WMA, Dolby AC3, MIDI, psychoacoustic model, perceptual audio coding technology
Knowledge/Experience in the following area will be a plus:
-Multimedia framework, such as DirectShow, GStreamer, OpenMAX, Android/OpenCORE etc;
-Speech codec such as G.723, G.729, G.711, GSM-AMR WB, GSM-AMR NB, QCELP, iLBC;
-Excellent fixed-point programming;
-Excellent verbal and written communication skills, in both English and Chinese;
-Excellent teamwork
-MSEE/CS or BSEE/CS with 3+ years of relevant working experience
发表于 2013-10-24 00:23:58 | 显示全部楼层
请问,已经在官网上投递了Physical Design Engineer,还能再发简历给你吗
发表于 2013-10-27 18:03:38 | 显示全部楼层
对职位1感兴趣,官网投了,还需要再投吗?本人应届小硕
GMT+8, 2025-11-7 00:58 , Processed in 0.016996 second(s), 5 queries , Gzip On, Redis On.
