查看: 4357|回复: 2
[求助] Antenna Rule疑惑求助
发表于 2013-10-18 10:25:52 | 显示全部楼层 |阅读模式
最近在做一个项目,Fab提供的Antenna Rule中有如下语句,看了半天不明白,有了解的帮忙解读一下,谢谢!!
M1_DIO = NET AREA RATIO SD M1 > 0
M1_MIN_DIO = NET AREA M1_DIO > 0.203  // minimum effective diode 0.203
ANT.c.a1 { @ (M1 perim*thickness / gate area) > 400 (without effective diode)
                 @ (M1 perim*thickness / gate area) > Ratio (with effective diode)
  NET AREA RATIO M1 M1_MIN_DIO GATE > 0     // no effective diode
       !!AREA(M1) * !!AREA(GATE) *
       !AREA(M1_MIN_DIO)*
                ( PERIMETER(M1)*0.43/AREA(GATE) - 400 ) +
       !!AREA(M1_MIN_DIO)*
                ( PERIMETER(M1)*0.43/AREA(GATE) - AREA(M1_MIN_DIO)*400 - 2200 )
      ] RDB ANT.c.a1.rep M1 M1_MIN_DIO GATE
前面都好理解,但是从!!开始就不是很理解了,!!符号是啥意思啊?
 楼主| 发表于 2013-10-22 10:58:10 | 显示全部楼层
怎么没人回啊
发表于 2013-10-27 15:11:58 | 显示全部楼层
回复 2# Rucas
    ! :returns a 1 (true) if its argument is 0;
        returns 0 (false) otherwise.
example:
!AREA(poly)
   :   returns a 1 if there is no poly in the data capture window.
       returns 0 if there is poly present in the capture window.
GMT+8, 2025-12-29 02:09 , Processed in 0.017913 second(s), 6 queries , Gzip On, Redis On.
