查看: 2973|回复: 1
[求助] 求教v2lvs参数的一些问题
发表于 2013-10-12 14:42:54 | 显示全部楼层 |阅读模式
v2lvs 中 -lsr和-lsp两个选项有何区别。
当我使用-lsp  bmr_ram8x72.cdl时候,会出现warning:nse_3360_top/cam_control_top_bmr_top_bmr_ram8x576_bmr_ram7 call port Q not declared in module bmr_ram8x72
当我使用-lsr  bmr_ram8x72.cdl时候,则没出现warning。
没太理解这两条的区别在哪。
· -lsp spice_library_file
Specifies SPICE library file name using pin mode. The SPICE file is parsed for
interface configurations. Pins with pin select ([ ]) annotation are kept as
individual pins using escaped identifiers.
· -lsr spice_library_file
Specifies SPICE library file name using range mode. The SPICE file is parsed
for interface configurations. Pins with pin select ([ ]) annotation are assembled
into Verilog ranges.
求大家给些指点啊!
发表于 2013-10-12 16:37:30 | 显示全部楼层
回复 1# zzallok
   个人认为 ,lsp把pin bus 分离成独立的Pin。
GMT+8, 2025-12-24 21:02 , Processed in 0.024490 second(s), 7 queries , Gzip On, Redis On.
