查看: 1804|回复: 1
[讨论] Matrix Converter Design
发表于 2013-10-2 15:37:27 | 显示全部楼层 |阅读模式
hi,
I want to design the matrix converter given in the attached file. There is an AC source connected to the bidirectional switches. How gates are derived in this situation? I have generated required signal patterns using pic controller and each signal is isolated via opto coupler. I don't know how to interface the  output side of the opto coupler to the matrix converter switches gates? Do i need to use mosfet driver like irs2110 for driving high side and low side switches?
A High Power Factor Matr ix AC to DC Converter Using Atmega 32 as the Signal Generator.pdf
122.43 KB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2013-10-2 19:07:38 | 显示全部楼层
here is the link for this converter
http://irnetexplore.ac.in/IRNetE ... 012_doc/paper11.pdf
I want to know how mosfet gates are derived. Because the bridge has ac source across it.
GMT+8, 2025-9-14 03:47 , Processed in 0.014509 second(s), 6 queries , Gzip On, Redis On.
