查看: 3212|回复: 1
Cadence SPB OrCAD 16.50.047 Hotfix 升级补丁
发表于 2013-9-9 19:43:22 | 显示全部楼层 |阅读模式
Cadence SPB OrCAD 16 最新的升级补丁,版本号16.50.47,修正内容如下:
DATE: 09-6-2013 HOTFIX VERSION: 047
CCRID PRODUCT PRODUCTLEVEL2 TITLE
1095533 CONCEPT_HDL CORE changing visibility for $PNN results in crash in windows mode
1153813 CONCEPT_HDL CORE Spaces should not be allowed in the signal name entry form
1156102 PCB_LIBRARIAN CORE PDV severe performance degradation on Linux platform makes PDV counter productive after some time
1161781 CONSTRAINT_MGR CONCEPT_HDL SigXp crash when selecting ECset in design
1163709 CONCEPT_HDL CONSTRAINT_MGR Loosing Diffpairs when reimport block or restore from definitioin
1167887 F2B OTHER Improve message on symbol to schematic generation
1168496 ALLEGRO_EDITOR SCHEM_FTB Export Physical Crashes when netreving the board
1168830 ALLEGRO_EDITOR DRC_CONSTR missing DRC-marker for package to package check
1169593 CONCEPT_HDL PDF Published PDF file\'s hyperlinks do not work fine when user click 1D10 or 2A10.
1169984 F2B PACKAGERXL Error Mapping cset when packaging but not in CM Audit
1171136 CONCEPT_HDL CORE Page Number should also be displayed in Import Design Window.
1172597 ALLEGRO_EDITOR DATABASE Board cannot be unlocked using Password used while locking
1172938 ALLEGRO_EDITOR PLOTTING Export IPF probrem
1173183 ALLEGRO_EDITOR DRC_CONSTR Undesired Same net DRC for overlapping Pin and Via
1173829 ALLEGRO_EDITOR MANUFACT Backdrill completes even though a stub exceeds the MAX_PTH_STUB value
1178972 CONSTRAINT_MGR ANALYSIS The Cross-Section\'s parameters was not applied immediately after importing a DCF on the Constraint Manager.
Download uploaded
http://uploaded.net/file/rkuje5qg/decsor1650047hf.rar
Download freakshare
http://freakshare.com/files/3bn5vdqg/decsor1650047hf.rar.html
Download filefactory
http://www.filefactory.com/file/73sm1uofqesd/n/decsor1650047hf.rar
Download 城通网盘
http://www.400gb.com/file/29444112
发表于 2014-11-2 16:01:37 | 显示全部楼层
谢谢楼主!
GMT+8, 2025-12-27 17:03 , Processed in 0.021613 second(s), 7 queries , Gzip On, Redis On.
