查看: 2363|回复: 5
IC5141 USR6 安装97%遇到问题 急!!球高手前辈
发表于 2013-8-23 13:32:40 | 显示全部楼层 |阅读模式
Mount IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 .
This CD-ROM is IC5141 lnx86 ISR 200811110850 CDROM # 1 .
Your package selections require IC5141 lnx86 P/N 356-70352-0501 CDROM # 1.
    1) Mount IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 on /instal/IC50.46.006_lnx86.Update/CDROM1
       and install packages contained on it.
    2) Skip IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 and
       proceed with the installation.
       is NOT available at this time.
    3) IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 already mounted on /instal/IC50.46.006_lnx86.Update/CDROM1, continue.
    4) Change CD-ROM mount point.
    m) Main Menu
Type your choice:
请问这时候我该如何选择  base的3个文件夹目录我有的  选了1以后出现如下提示:
Use the provided shell to log in as root and mount
After you have mounted this CD-ROM, type 'exit' to continue installation.
sh-3.00$
求助
问题补充:
1
1
以上是我下载的资源,请问前两个压缩包我应该选择哪个,还有在windows下解压成文件夹形式再复制进虚拟机里面安装,会不会有问题?
发表于 2013-8-23 13:45:16 | 显示全部楼层
解压文件
 楼主| 发表于 2013-8-23 13:47:58 | 显示全部楼层
回复 2# gengwd
    前辈您好 我已经解压完了 也复制进RHEL里面了 就是安装的时候遇到上面的问题 我该怎么办呢
发表于 2013-8-23 19:09:48 | 显示全部楼层
把路径指定到base的CDROM1就可以把
发表于 2013-8-27 12:31:39 | 显示全部楼层
    1) Mount IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 on /home/kury/cadence_install/update/CDROM1
    3) IC5141 lnx86 P/N 356-70352-0501 CDROM # 1 already mounted on /home/kury/cadence_install/update/CDROM1, continue.
    m) Main Menu
Type your choice: 4
        You must now identify where the CD-ROM is mounted.
           1)   Local           (mounted to this machine)
           2)   Remote          (mounted to another machine)
           m)   Main Menu
           h)   Help
        Type your choice: [ 1 ]        按“回车”
        Specify the CD-ROM mount point
           1)   /cdrom
           2)   Other
           m)   Main Menu
           p)   Previous Menu
           h)   Help
        Type your choice: [ 2 ]         按“回车”
        Type the CD-ROM mount point: [ /home/kury/cadence_install/update/CDROM1 ] /home/kury/cadence_install/base/CDROM1 输入存放路径,注意是BASE的,不是UPDATE的 (注:这是我的存放路径,你要改成你自己的存放路径)
(等待,直到100%)
loading edif300userDoc05.10-p002 ......................................
Installation of edif300userDoc05.10-p002 complete
Total Installation 100 % done
发表于 2014-4-12 17:57:18 | 显示全部楼层
把路径指定到base的CDROM1
GMT+8, 2025-12-14 13:17 , Processed in 0.021388 second(s), 10 queries , Gzip On, Redis On.
