查看: 1950|回复: 0
[求助] 找paper 265 V Mains Interface Integrated in 0.35 m CMOS
发表于 2013-8-1 12:31:59 | 显示全部楼层 |阅读模式
265 V Mains Interface Integrated in 0.35 m CMOS PDF
A fully integrated 265 VRMS input AC-DC interface is demonstrated in a 0.35-μm CMOS technology, requiring only one optional external low-voltage SMD capacitor for improved performance. The converter can directly interface the universal line voltage (50-60 Hz) and converts this into a regulated DC voltage of 3.3 V. High input voltage operation is made possible through separation of the mains input from the active circuits by custom layout high-voltage capable passive components in between. A compact model of an ideal AC-DC capacitive step-down converter is presented and the proposed circuit architecture is designed to mimic ideal operation and approach the maximum attainable power throughput accordingly. The prototype converter demonstrates a maximum output power of 12.7 μW on a die area of 6 mm2 and enables integrated circuits to be supplied straight from the ubiquitous mains voltage, hereby circumventing the need for traditional converters using expensive and bulky high-voltage discrete components.
                 Published in:
                                         Solid-State Circuits, IEEE Journal of                                                         (Volume:48                        ,                                  Issue:                                        7                        )
                                                    Date of Publication:                                July 2013
=>  who have this ??
GMT+8, 2025-12-22 14:30 , Processed in 0.017171 second(s), 5 queries , Gzip On, Redis On.
