查看: 2410|回复: 0
[原创] 求救!!!高手来指点小弟一下!先作揖了!!
发表于 2007-2-2 21:57:28 | 显示全部楼层 |阅读模式
#include"register.h"
void initial(void)
asm("setc SXM");
asm("clrc OVM");
asm("clrc CNF");
asm("setc INTM");
  *SCSR1=0x81FE;
  *WDCR=0x0E8;
  *IMR=0x0000;
  *IFR=0x0FFFF;
  *MCRA=*MCRA&0x0FF;
  *PBDATDIR=*PBDATDIR|0x0FF00;
  *MCRC=*MCRC&0X0FBFF;
  *PBDATDIR=*PBDATDIR&0X0FF00;
  *PFDATDIR=*PFDATDIR|0X0404;
  *PEDATDIR=*PFDATDIR&0X0FFFB;
main()
int led;
int i;
int k;
intial();
while(1)
for(led=0x0080,i=0;i<8;led=led>>1,i++)
    *PBDATDIR=*PBDATDIR&0x0ff00;
    *PBDATDIR=*PBDATDIR|led;
    *PFDATDIR=*PFDATDIR|0x0404;
    *PFDATDIR=*PFDATDIR&0x0fffb;
    for(k=0;k<0x0ffff;k++)
    k=k;
void interrupt nothing()
return;
编译结果
dspcl IO.C -g -v2xx -as -frC:\tic2xx\myprojects\IO
[IO.C]
TMS320C2x/C2xx/C5x ANSI C Compiler          Version 7.00
Copyright (c) 1987-1999  Texas Instruments Incorporated
   "IO.C"   ==> initial
"IO.C", line 9: [F022] illegal constant
"IO.C", line 9: [F001] syntax error at or near symbol '='
"IO.C", line 10: [F001] syntax error at or near symbol '='
"IO.C", line 11: [F108] 'Int' undefined
"IO.C", line 12: [F022] illegal constant
"IO.C", line 12: [F001] syntax error at or near symbol '='
"IO.C", line 13: [F022] illegal constant
"IO.C", line 13: [F001] syntax error at or near symbol '='
"IO.C", line 13: [F137] operand of '&' must be an object or function
"IO.C", line 14: [F022] illegal constant
"IO.C", line 14: [F001] syntax error at or near symbol '='
"IO.C", line 15: [F022] illegal constant
"IO.C", line 15: [F001] syntax error at or near symbol '='
"IO.C", line 15: [F137] operand of '&' must be an object or function
"IO.C", line 16: [F001] syntax error at or near symbol '='
"IO.C", line 16: [F137] operand of '&' must be an object or function
"IO.C", line 17: [F022] illegal constant
"IO.C", line 17: [F001] syntax error at or near symbol '='
"IO.C", line 18: [F022] illegal constant
"IO.C", line 18: [F001] syntax error at or near symbol '='
"IO.C", line 18: [F137] operand of '&' must be an object or function
   "IO.C"   ==> main
"IO.C", line 30: [F001] syntax error at or near symbol '='
"IO.C", line 30: [F137] operand of '&' must be an object or function
"IO.C", line 31: [F001] syntax error at or near symbol '='
"IO.C", line 32: [F001] syntax error at or near symbol '='
"IO.C", line 33: [F001] syntax error at or near symbol '='
"IO.C", line 33: [F137] operand of '&' must be an object or function
   "IO.C"   ==> nothing
Compile Complete,
  27 Errors, 0 Warnings.
小弟初学实在不明白为何有错,尤其是哪个“=”的语法错吴
程序绝对是在英文输入法下完成
求高手指点一下小第感激涕零!!!!
GMT+8, 2025-12-18 23:14 , Processed in 0.016939 second(s), 8 queries , Gzip On, Redis On.
