查看: 3745|回复: 7
IC615 ASSURA41 LVS ERROR
发表于 2013-7-26 11:08:46 | 显示全部楼层 |阅读模式
Hi all,
I'm using IC615 with ASSURA41 and i having a problem with the LVS. When i run it it has the following error:
Starting dfIIToVdb...
/root/cadence/installs/ASSURA41/tools/assura/bin/64bit/dfIIToVdb: /root/cadence/installs/ASSURA41/tools/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /root/cadence/installs/IC615/oa_v22.41.027/lib/linux_rhel40_gcc44x_32/opt/liboaPlugIn.so)
/root/cadence/installs/ASSURA41/tools/assura/bin/64bit/dfIIToVdb: /root/cadence/installs/ASSURA41/tools/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /root/cadence/installs/IC615/oa_v22.41.027/lib/linux_rhel40_gcc44x_32/opt/liboaCommon.so)
*WARNING* Translation abnormally terminated!
anyone can help?
发表于 2014-4-25 13:21:32 | 显示全部楼层
OA版本不兼容吧
发表于 2014-7-13 16:01:04 | 显示全部楼层
文件”/root/cadence/installs/ASSURA41/tools/lib/libstdc++.so.6“不支持”GLIBCXX_3.4.9“。
把操作系统“/usr/lib"下的libstdc++文件连接到这个位置就行了。
发表于 2014-9-13 13:32:19 | 显示全部楼层
涨涨人气
发表于 2014-9-15 09:39:26 | 显示全部楼层
涨涨人气
发表于 2015-2-26 17:00:26 | 显示全部楼层
回复 3# thx1234
   改后程序直接崩溃了
发表于 2017-5-25 13:42:41 | 显示全部楼层
请问下楼主,解决了这个问题没?
发表于 2018-1-16 23:57:50 | 显示全部楼层
unset OA_HOME
GMT+8, 2025-9-14 04:18 , Processed in 0.016981 second(s), 6 queries , Gzip On, Redis On.
