查看: 3922|回复: 5
[求助] ICC设计中到了pre placement的时候check出现了一个False
发表于 2013-7-3 15:01:39 | 显示全部楼层 |阅读模式
RT,就是马上要进行Placement了,然后这个时候运行check_physical_design -stage pre_place_opt -output ../out 的
时候,一敲完这个指令,马上就接着一个False,然后就是checking tluplus...最后的一个report中并没有报道error和warning,觉得很不正常,不知道是什么引起的,望大侠多多帮助啊~~
发表于 2013-7-3 17:11:34 | 显示全部楼层
没有Error/Warning就OK
 楼主| 发表于 2013-7-4 09:02:24 | 显示全部楼层
回复 2# xjg@hmes
    额,这样没有风险吗?感觉很不正常似得,一个error和warning都没有
发表于 2013-7-4 11:30:23 | 显示全部楼层
贴log上来
发表于 2013-7-12 14:00:27 | 显示全部楼层
回复 2# xjg@hmes
    大侠:请问一下啊,工艺是$imc018的在create_mw_lib指令时候,报出了以下warning,不知道是否可以忽略:
Waring:Layer 'METAL1' has a pitch 0.56 that dose not match the recommended wire-to-via pitch 0.535 or 0.485.
Waring:Layer 'METAL5' has a pitch 0.56 that dose not match the recommended wire-to-via pitch 0.66 or 0.61.
Waring:Layer 'METAL3' has a pitch 0.56 that dose not match the doubled pitch 1.12 or tripled pitch 1.68.
Waring:Layer 'METAL4' has a pitch 0.56 that dose not match the doubled pitch 1.12 or tripled pitch 1.68.
Waring:Layer 'METAL5' has a pitch 0.56 that dose not match the doubled pitch 1.12 or tripled pitch 1.68.
Waring:Layer 'METAL6' has a pitch 0.95 that dose not match the doubled pitch 1.12 or tripled pitch 1.68.
虽然是warning但是看着not match这几个显眼的字眼,还是很不放心,
发表于 2013-7-12 14:01:44 | 显示全部楼层
回复 4# overdriver
GMT+8, 2025-10-31 05:53 , Processed in 0.013578 second(s), 3 queries , Gzip On, Redis On.
