查看: 4140|回复: 6
[调查] Aldec.Riviera-PRO.v2012.06. crack problemjavascript:;
发表于 2013-7-2 03:48:36 | 显示全部楼层 |阅读模式
I have cracked version of Aldec.Riviera-PRO.v2012.06. But, when i run it after a short time it closed automatically. I think it is the crack problem!! Is there any body that can provide me a stable crack of Aldec.Riviera-PRO.v2012.06??
发表于 2013-12-24 21:38:15 | 显示全部楼层
same problem!
发表于 2014-1-6 00:27:16 | 显示全部楼层
same problem any one has solution?
发表于 2014-1-6 02:02:06 | 显示全部楼层
check that patched files  last modification time is the same as for original ones.
发表于 2014-1-14 19:11:06 | 显示全部楼层
problem found:
it is wrong license syntax !
if anybody find valid expired license from aldec for 2010-2013 years i make the working crk.
发表于 2014-1-23 01:02:24 | 显示全部楼层
Found the cause of Riviera termination:
There are the FEATURE-terminator: RIVIERAPRO_ALL_FEATURES.
If delete this FEATURE from EFA-team license the soft start work OK.
The patch is worked.
发表于 2015-1-21 12:56:17 | 显示全部楼层
I need Aldec 2014
GMT+8, 2025-9-15 05:27 , Processed in 0.016932 second(s), 7 queries , Gzip On, Redis On.
