楼主: fuyibin
关于PLL的Matlab仿真
发表于 2009-3-8 09:14:20 | 显示全部楼层
PDF 能用DFF和AND搭,LPF用transfer function,simulink 有现成的vco
发表于 2009-3-9 14:27:44 | 显示全部楼层
You can use Matlab(simulink or M-file), but some ppl may be not familiar with Matlab or system level modeling.
Now, I will tell you as long as you know how to draw schematic in Cadence, you can easily build a PLL system level model and simulate with Spectre.
All you need:
(1) VCVS, VCCS
(2) Vpulse,
(3) R,C
Using this model, you can run AC, transient and noise analysis etc. And it is at least 100X faster than real circuit simulations.
Moreover, this model is very easy to build, modify to fit all kinds of PLL, liks SSPLL, FNPLL etc.
The essential concept for my method is using phase domain to build the schematic. You will find it is very interesting and amazing it works so fine.Unbelievable but it really works!
发表于 2009-4-22 20:10:17 | 显示全部楼层
matlab方便产生时域波形吗?
有人做过PLL的Z域模型吗?
发表于 2009-6-23 19:21:35 | 显示全部楼层
也想知道,等待大家上传好资料
发表于 2009-7-31 16:44:29 | 显示全部楼层
也想知道,等待大家上传好资料
发表于 2011-3-10 13:53:18 | 显示全部楼层
发表于 2011-12-27 09:56:35 | 显示全部楼层
期待高手的出现
发表于 2014-10-20 13:21:44 | 显示全部楼层
回复 22# prof3
   LS,请教一下?这个可以用来仿真PLL的phase noise,如果可以的话,具体怎么实现呢
发表于 2015-11-24 10:42:53 | 显示全部楼层
期待高手的出现
发表于 2015-11-24 13:40:42 | 显示全部楼层
回复 21# greggreg
   我试试看,谢啦!
GMT+8, 2025-10-30 00:11 , Processed in 0.018223 second(s), 4 queries , Gzip On, Redis On.
