查看: 11592|回复: 30
[资料] IC compiler reference Methodology script vG-2012.06
发表于 2013-6-21 12:49:29 | 显示全部楼层 |阅读模式
G-2012.06
The following sections describe new features, changes, and enhancements in the
IC Compiler Reference Methodology version G-2012.06.
UPF Updates
The following updates have been made for IEEE 1801, which is also known as
Unified Power Format (UPF):
*  Support has been added in icc_setup.tcl for creating supply set handles when
   you create power domains with the upf_create_implicit_supply_sets variable.
*  The derive_pg_connection -create_net command has been added in
   init_design_icc.tcl for the Synopsys logical database format (.ddc) based flow.
*  Support has been added in outputs_icc.tcl for the write_link_library command:
   write_link_library -full_path_lib_names \
      -output $RESULTS_DIR/write_link_library.tcl"
   PrimeTime uses the file produced by this command to identify the correct
   libraries to link for cells powered by non-primary power nets.
*  The filtering options for the all_level_shifters and all_ao_cells commands have
   been updated with the following expression in place_opt_icc.tcl and
   route_icc.tcl:
   within_block_abstraction==false && within_ilm==false
   This update ensures that all_level_shifters and all_ao_cells keep the same
   behavior they had in previous releases, which means they are applied on the
   top-level hierarchy only.
place_opt Update
Comments have been added in place_opt_icc.tcl to support intercell spacing
constraints between library cells with the set_lib_cell_spacing_label and
set_spacing_label_rule commands.
Physical Guidance Update
Support for ASCII input has been added in the physical guidance flow. Previously,
only the binary input was supported. The messages and commands have been updated
in init_design_icc.tcl and place_opt_icc.
A new variable, ICC_IN_SPG_DEF_FILE, has been added to specify a Design Exchange
Format (DEF) file that contains physical guidance placement information from the
Design Compiler Reference Methodology. The default naming convention for this file
is ${DESIGN_NAME}.mapped.std_cell.def.
You should use ICC_IN_SPG_DEF_FILE for physical guidance placement information
and use ICC_IN_DEF_FILE for non-physical-guidance related floorplan information.
Clock Tree Synthesis Update
The CLOCK NDR and CLOCKSHIELDING NDR sections on the sequence of command execution
have been updated in common_cts_settings_icc.tcl.
In addition, the ICC_CTS_SHIELD_MODE variable is no longer required and has been
removed.
Route and Postroute Optimization Updates
*  A new option, Zroute, has been added in RMgen.
   This option allows you to choose between Zroute or the classic router.
   To generate only Zroute scripts, select TRUE. To generate only classic router
   scripts, select FALSE.
*  The check_routeability command has been replaced by the check_zrt_routeability
   command in rm_icc_zrt_scripts/route_icc.tcl.
   This change applies only when you select TRUE for the Zroute option in RMgen.
*  The -analysis_effort medium option has been added to the set_si_options command
   and other set_si_options examples in common_route_si_settings_zrt_icc.tcl.
   To improve DRC convergence for newer technology nodes, such as 28nm and below,
   a comment has been added that suggests changing the search and repair loop for
   the route_opt -initial_route command from 10 to 40.
   This comment appears only when you select TRUE for the Zroute option in RMgen.
*  The comments regarding power-aware optimization and power recovery have been
   updated in route_opt_icc.tcl.
*  Comments have been added in common_route_si_settings_zrt_icc.tcl suggesting
   that you increase the search and repair loops from 10 to 40 for the
   route_opt -initial command for newer technology nodes (28nm and below).
   Comments have also been added suggesting that you disable the minimum area and
   length checks for the cell pins feature for older technology nodes
   (40nm and above).
*  Comments regarding filler cell handling have been added in route_opt_icc.tcl
   and focal_opt_icc.tcl.
   When running route_opt or focal_opt with filler cells placed, the filler cell
   type must be std_filler.
ICC-RM_G-2012.06.tar (560 KB , 下载次数: 231 )
ICC-RM_G-2012.06-SP4.tar (580 KB , 下载次数: 238 )
发表于 2013-7-17 20:24:58 | 显示全部楼层
这么小的文件还压缩成两个????
发表于 2013-7-17 20:26:26 | 显示全部楼层
是从synopsis LINX上面下载下来的吧?
发表于 2013-8-3 21:38:00 | 显示全部楼层
不错不错,Thank you
发表于 2013-8-3 21:39:01 | 显示全部楼层
不错不错,Thank you!!!!
发表于 2013-8-23 00:27:02 | 显示全部楼层
最好能合成一个包就好了
发表于 2013-8-24 13:05:13 | 显示全部楼层
不错不错,Thank you
发表于 2013-8-24 13:05:33 | 显示全部楼层
不错不错,Thank you
发表于 2014-8-5 20:31:30 | 显示全部楼层
谢谢大美女!
发表于 2014-8-18 09:44:26 | 显示全部楼层
Have a good job !
GMT+8, 2025-12-26 18:48 , Processed in 0.029057 second(s), 6 queries , Gzip On, Redis On.
