查看: 11101|回复: 11
[求助] DC出了一溜相同的警告,不太明白
发表于 2013-6-6 21:48:55 | 显示全部楼层 |阅读模式
Verilog writer has added 1 nets to module halfband3_DW02_mult_17 using SYNOPSYS_UNCONNECTED_ as prefix.  Please use the change_names command to make th e correct changes before invoking the verilog writer.(VO-11)
就是上面这句话,其他警告就是把17这个数字换成了别的数字,还望论坛里的高手赐教我需要怎么做啊
 楼主| 发表于 2013-6-6 21:50:23 | 显示全部楼层
Warning: Verilog 'assign' or 'tran' statements are written out. (VO-4)
Warning: Verilog writer has added 1 nets to module halfband_DW02_mult_3 using SY NOPSYS_UNCONNECTED_ as prefix.  Please use the change_names command to make the correct changes before invoking the verilog writer.  (VO-11)
Warning: Verilog writer has added 1 nets to module halfband_DW02_mult_1 using SY NOPSYS_UNCONNECTED_ as prefix.  Please use the change_names command to make the correct changes before invoking the verilog writer.  (VO-11)
Warning: Verilog writer has added 27 nets to module halfband using SYNOPSYS_UNCO NNECTED_ as prefix.  Please use the change_names command to make the correct cha nges before invoking the verilog writer.  (VO-11)
 楼主| 发表于 2013-6-6 21:52:24 | 显示全部楼层
初学者,还不太明白
发表于 2013-6-7 07:42:26 | 显示全部楼层
暂时忽略
 楼主| 发表于 2013-6-7 13:30:55 | 显示全部楼层
回复 4# 陈涛
然后我在做ICC时就出现了很多类似下面的错误,还请赐教是怎么回事啊?
   Error: Port 'halfband_out_f[2]' cannot inherit its location from the pin 'hb3/out_r_reg[18]/Q', because the cell 'hb3/out_r_reg[18]' is neither a pad-cell nor a macro-cell. Please check the library. (PSYN-117)
发表于 2013-6-7 13:37:17 | 显示全部楼层
没看出来它们之间有什么联系
 楼主| 发表于 2013-6-7 13:57:38 | 显示全部楼层
回复 6# 陈涛
那后来这个错误是什么原因造成的?我们的指导老师根本就不会这个,全是我们自己在摸索
发表于 2013-6-7 14:21:44 | 显示全部楼层
把完整的command和mesage贴出来
发表于 2019-7-19 21:25:59 | 显示全部楼层
楼主问题解决了没
发表于 2021-10-5 10:21:31 | 显示全部楼层
lyh070916 发表于 2013-6-7 13:30
回复 4# 陈涛
后面那个应该是port在原点,通过create_terminal把它移到Q点就可以了
GMT+8, 2025-12-28 09:48 , Processed in 0.018417 second(s), 4 queries , Gzip On, Redis On.
