查看: 13605|回复: 25
[求助] PT和ICC结果不一致
发表于 2013-6-6 15:41:02 | 显示全部楼层 |阅读模式
最近在做PT, 发现PT的结果和ICC的不一致.ICC下没有任何violation,但是在PT下却显示既有setup violations又有hold violations,setup violations都是发生在output port.
我把icc pt timing report贴在下面。各位大虾能否帮忙查一下是什么原因导致这种情况发生吗?非常感谢!
ICC的报告:
Startpoint: tgen_inst/g_data_o_reg_2_
              (falling edge-triggered flip-flop clocked by CLKIN)
  Endpoint: dat[8] (output port clocked by CLKIN)
  Scenario: SCN2
  Path Group: CLKIN
  Path Type: max
  Point                                    Incr       Path      Voltage
  clock CLKIN (fall edge)                  9.25       9.25
  clock network delay (propagated)         3.02      12.27
  tgen_inst/g_data_o_reg_2_/T (FEMS)       0.00      12.27 f    3.00
  tgen_inst/g_data_o_reg_2_/Q (FEMS)       0.74      13.01 f    3.00
  tgen_inst/g_data_o[2] (tgen)             0.00      13.01 f    3.00
  icc_clock197/Y (LU2S)                    0.29 &    13.30 r    3.00
  icc_clock198/YC (K02S)                   0.09 &    13.39 f    3.00
  icc_clock203/Y (V01S)                    0.60 &    13.98 r    3.00
  icc_clock202/Y (V01Q)                    0.57 &    14.55 f    3.00
  dat[8] (out)                             0.06 &    14.61 f    3.00
  data arrival time                                  14.61
  clock CLKIN (rise edge)                 18.50      18.50
  clock network delay (ideal)              2.00      20.50
  clock reconvergence pessimism            0.00      20.50
  clock uncertainty                       -0.50      20.00
  output external delay                   -4.00      16.00
  data required time                                 16.00
  data arrival time                                 -14.61
  slack (MET)                                         1.39
PT的报告:
  Path Group: grp_outputs
  Path Type: max
  Point                                           Incr       Path
  clock network delay (propagated)                4.23      13.48
  tgen_inst/g_data_o_reg_2_/T (FEMS)              0.00      13.48 f
  tgen_inst/g_data_o_reg_2_/Q (FEMS)              0.73 &    14.21 f
  icc_clock197/Y (LU2S)                           0.29 &    14.50 r
  icc_clock198/YC (K02S)                          0.07 &    14.57 f
  icc_clock203/Y (V01S)                           0.54 &    15.12 r
  icc_clock202/Y (V01Q)                           0.18 &    15.29 f
  dat[8] (out)                                    0.01 &    15.31 f
  data arrival time                                         15.31
  clock network delay (propagated)                0.00      18.50
  clock reconvergence pessimism                   0.00      18.50
  clock uncertainty                              -0.50      18.00
  output external delay                          -4.00      14.00
  data required time                                        14.00
  data arrival time                                             -15.31
  slack (VIOLATED)                                          -1.31
发表于 2013-6-7 07:50:26 | 显示全部楼层
你要是去掉这个的话,ICC一样有violation
 楼主| 发表于 2013-6-7 08:55:05 | 显示全部楼层
回复 2# 陈涛
    请教一下陈版主,ICC的clock network delay(ideal) 是怎么加进去的?是ICC默认的吗?为什么PT没有呢?
发表于 2013-6-7 09:14:15 | 显示全部楼层
ICC中cts完要 set_propagated_clocks [all_clocks]
另外,你有set_clock_latency的设定吧?让工具自己计算latency
发表于 2013-6-7 09:16:41 | 显示全部楼层
回复 3# justsfy2013
估计你的sdc里有把时钟设置为ideal
 楼主| 发表于 2013-6-7 10:51:37 | 显示全部楼层
查了一下sdc,里面没有set_ideal_clock.
ICC的脚本里在place_opt这一步有set_ideal_clock,但是在clock_opt_cts之后,clock_opt_psyn之前已经去掉了这一选项。
ICC报timing的时候reg to reg的path,clock_network_delay 是propagated属性,只是output port显示的是ideal.
发表于 2013-6-7 11:53:43 | 显示全部楼层
clock CLKIN 在sdc里是ideal的可能
发表于 2013-6-7 16:49:43 | 显示全部楼层
回复 1# justsfy2013
你的ICC脚本中可能有 update_clock_latency 命令?
发表于 2013-6-7 16:53:32 | 显示全部楼层
如果有update_clock_latency的话,去掉这个命令,
然后,设置 set_clock_latency 0 CLKIN,试试。
 楼主| 发表于 2013-6-8 09:33:20 | 显示全部楼层
脚本里面的clock_opt里面倒是有updata_clock_latency这个选项,但是这个选项没有开。
GMT+8, 2025-12-23 12:35 , Processed in 0.025104 second(s), 5 queries , Gzip On, Redis On.
