查看: 2877|回复: 2
[求助] HSPICE2010.3 licence导入问题,非常奇怪的问题
发表于 2013-4-21 12:56:35 | 显示全部楼层 |阅读模式
报错如下
  1. 12:50:39 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
  2. 12:50:39 (lmgrd) US Patents 5,390,297 and 5,671,412.
  3. 12:50:39 (lmgrd) World Wide Web:  http://www.macrovision.com
  4. 12:50:39 (lmgrd) License file(s): /home/wt/eda/synopsys/synopsys.dat
  5. 12:50:39 (lmgrd) lmgrd tcp-port 27000
  6. 12:50:39 (lmgrd) Starting vendor daemons ...
  7. 12:50:39 (lmgrd) Started /home/wt/e (internet tcp_port 39900 pid 2548)
  8. 12:50:39 (lmgrd) license daemon: execute process failed: (/home/wt/eda/synopsys/scl_10.9.3/linux/bin//home/wt/e) -T wthust 10.8 3 -c /home/wt/eda/synopsys/synopsys.dat
  9. 12:50:39 (lmgrd) license daemon: system error code: No such file or directory
  10. 12:50:39 (lmgrd) /home/wt/e exited with status 45 (Child cannot exec requested server)
  11. 12:50:39 (lmgrd) Please correct problem and restart daemons
  12.
    复制代码
另外使用lmdown 27000@wthust时出现
  1. wt@wthust:~$ lmdown -c 27000@wthust
  2. lmdown - Copyright (c) 1989-2004 by Macrovision Corporation. All rights reserved.
  3.    Port@Host            Vendors
  4. 1) 27000@wthust         /home/wt/e
  5. Are you sure (y/n)?
  6.
    复制代码
另外我的环境变量是这样的
  1. ####### Configurations for Synopsys Hspice ######
  2. export SYNOPSYS_HOME=/home/wt/eda/synopsys
  3. export HSP_HOME=$SYNOPSYS_HOME/hspice_vD-2010.03
  4. export SCL_HOME=$SYNOPSYS_HOME/scl_10.9.3
  5. export HSP_BIN=$HSP_HOME/hspice/bin
  6. export SCL_BIN=$SCL_HOME/linux/bin
  7. export SX_BIN=$SYNOPSYS_HOME/spice_explorer_2007
  8. export PATH=$HSP_BIN:$SX_BIN:$PATH
  9. export LM_LICENSE_FILE=$SYNOPSYS_HOME/synopsys.dat:\
  10. 27000@wthust:$LM_LICENSE_FILE
  11. ####### Customed alias for commands ########
  12. alias hsplmd='$SCL_BIN/lmgrd -c $SYNOPSYS_HOME/synopsys.dat'
  13.
    复制代码
那个 /home/wt/e路径是怎么回事?求大神解答
发表于 2013-4-21 23:39:21 | 显示全部楼层
你有把synopsys.dat文件拷贝到/home/wt/eda/synopsys/目录下,而且确定该LICENCE文件正确吗?
发表于 2013-8-4 14:10:56 | 显示全部楼层
这些路径替代是不用export的
export PATH=$HSP_BINSX_BINPATH
这才用的
GMT+8, 2025-12-16 04:19 , Processed in 0.021897 second(s), 4 queries , Gzip On, Redis On.
