[求助] 求助贴,关于运放结构实现的比较器功能
发表于 2013-4-8 20:06:07 | 显示全部楼层
感觉和有可能是你的M5/M6的输入电容太大
然后第一级的bias current太小导致的slew问题
发表于 2013-4-8 22:39:06 | 显示全部楼层
回复 4# 腐朽的青春99
    You just tell me the working principle of a comparator, not application.
    Application means where you will use your comparator. Maybe it's not convenient to tell me.
    So what's your application's requirement ?
    high speed ? high resolution ? or both ? .......
    The speed of a static comparator normally limited by linear response and slew-rate.
    Your ciruit maybe limited by slew-rate.
    But don't forget that the speed of linear response of a comparator is limited by -3dB freq, not GBW.
    GBW just shows the tradeoff.
    If you have specific speed requirement, you have a specific -3dB freq requirement.
 楼主| 发表于 2013-4-9 08:59:13 | 显示全部楼层
回复 12# feynmancgz
Thank you for your patient guidance。
发表于 2013-4-23 15:45:26 | 显示全部楼层
Mark。
发表于 2013-4-23 15:45:55 | 显示全部楼层
回复 1# 腐朽的青春99
感觉这种结构的延迟就是纳秒级的吧,除非电流取到很大
 楼主| 发表于 2013-4-24 10:39:56 | 显示全部楼层
回复 15# tangyaoyun
   现在我得出的也就是几个ns,看MIT的论文,他们做出的结果和普通的锁存比较器结果差不多,能达到200个ps。
发表于 2013-4-24 11:28:04 | 显示全部楼层
回复 16# 腐朽的青春99
把电流加大呗,想要多快都可以,要不就用小尺寸器件,或者用低阈值滴管子
 楼主| 发表于 2013-4-24 12:14:48 | 显示全部楼层
回复 17# tangyaoyun
多谢
发表于 2014-8-29 08:38:24 | 显示全部楼层
多谢楼主分享
发表于 2024-5-16 12:27:08 | 显示全部楼层
能把论文贴出来看看吗?谢谢
GMT+8, 2025-11-6 05:40 , Processed in 0.029911 second(s), 3 queries , Gzip On, Redis On.
