查看: 7522|回复: 19
[求助] 求助贴,关于运放结构实现的比较器功能
发表于 2013-4-8 18:17:58 | 显示全部楼层 |阅读模式
1.png 参考国外的毕业论文设计,一个采用如图结构的电路,用于比较两个输入端电压的值,参考的文章比较的延时可以达到200ps,但是我仿出来数量级都差了好多,大概在几十个纳秒。开关电容结构的比较器由于采用了正反馈结构可以达到几百个ps,这种结构可能吗?如果不行的话,应该采用怎么样的结构,才能实现?求大神帮忙啊
发表于 2013-4-8 18:52:34 | 显示全部楼层
回复 1# 腐朽的青春99
    What is the application of your comparator ?
    Which kind of technology do you use ?
    Have you ever calculate the bandwidth of your comparator ?
    Is your application allowed to use dynamic comparator ?
    Have you considered preamp+latch structure ?
发表于 2013-4-8 19:11:41 | 显示全部楼层
可以看看martin的模电,专门有一章讲比较器
 楼主| 发表于 2013-4-8 19:26:17 | 显示全部楼层
回复 2# feynmancgz
Thank you for the questions.The comparator is used to detect the two inputs' zero crossing point,which means the two inputs change their conditions that one is bigger than the other one to the opposite.The design is under 180nm technology ,which is longer than the original design.
The bandwidth is about 200M,with a load of 1pF capacitor.
In my application ,clock-controlled comparators can't be used ,which means dynamic comparator is not suitable.
You mentioned that pream+latch may be a good idea ,but does it work without a preset?
 楼主| 发表于 2013-4-8 19:27:12 | 显示全部楼层
回复 3# Timme
   Thank you
 楼主| 发表于 2013-4-8 19:27:19 | 显示全部楼层
回复 3# Timme
   Thank you
发表于 2013-4-8 19:35:25 | 显示全部楼层
200MHz带宽,时延有几十个ns?
你AC仿出来确定是200MHz?GBW?
 楼主| 发表于 2013-4-8 19:40:20 | 显示全部楼层
回复 7# tideblue
   GBW
发表于 2013-4-8 19:45:56 | 显示全部楼层
你M5/M6的size?
还有差分运放的bias current?
 楼主| 发表于 2013-4-8 19:53:24 | 显示全部楼层
回复 9# tideblue
M5 is sized to be 20x larger compared to M6 in order to minimize the delay
of the ZCD. The transconductance of M5 is much larger compared to that of M6
GMT+8, 2025-11-6 03:22 , Processed in 0.027475 second(s), 6 queries , Gzip On, Redis On.
