查看: 16151|回复: 35
[求助] 折叠式共源共栅的极点问题
头像被屏蔽
发表于 2013-3-21 16:05:42 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2013-3-21 17:27:34 | 显示全部楼层
不是drain
这个非主极点在M5的gate
发表于 2013-3-21 21:05:13 | 显示全部楼层
回复 1# jxjxhwx
   the equivalence resistance at the drain of M5 is much, much lower than 1/gm9 because of the feedback loop around M5 and M9. The pole at the drain of M5 located at very, very, very high frequency
头像被屏蔽
 楼主| 发表于 2013-3-21 21:34:25 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
 楼主| 发表于 2013-3-21 21:36:07 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2013-3-21 21:58:13 | 显示全部楼层
回复 4# jxjxhwx
    I don't think your analysis is right.
    Firstly, why do you think the voltage at the drain of M9 will increase by (gm*ro)^2 times ?
    Secondly, why do you think Cgd of M5 will increase the same time ?
    Show me the fomulas you used.
头像被屏蔽
 楼主| 发表于 2013-3-21 22:11:43 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2013-3-21 22:13:40 | 显示全部楼层
回复 4# jxjxhwx
M9 source 到 drain 增益是 gm9*Rout
M5 的等效电阻大约是1/gm9(gm5*Rout-1)
非常非常小
头像被屏蔽
 楼主| 发表于 2013-3-21 22:16:35 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2013-3-21 22:23:40 | 显示全部楼层
回复 7# jxjxhwx
    I do not understand why you think C will increase
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 07:33 , Processed in 0.023856 second(s), 7 queries , Gzip On, Redis On.
