楼主: sendyqq
[求助] Cadence IC 615用MMSIM12.1仿真出现Error found by spectre during AHDL read-in.
发表于 2015-7-4 11:14:58 | 显示全部楼层
gooooooooooooooooood
发表于 2015-8-14 14:50:08 | 显示全部楼层
求解打啊
发表于 2015-12-27 14:45:19 | 显示全部楼层
回复 1# sendyqq
可以按照说明:spectre/schematic/netlist/input.ahdlSimDB/bsource.va.bsource_1.ahdlcmi/ahdlcmi.out文件的具体错误说明
本人的文件中可以看到错误:/usr/include/gnu/stubs.h:7:27: error: gnu/stubs-32.h: No such file or directory
查看/usr/include/gnu文件夹下确实没有stubs-32.h(rhel5-64bit系统)
解决:安装glibc-devel-2.5-81.i386.rpm
rpm -ivh glibc-devel-2.5-81.i386.rpm
该文件在Redhat系统安装盘Server路径下
Good luck!
发表于 2017-7-8 17:20:10 | 显示全部楼层
这贴超级有效,多查查更健康。
发表于 2018-5-13 16:20:12 | 显示全部楼层
我是UBUNTU14.04 64bit,MMSIM141也是64位的。
spectre能正常仿真,APS会出现  ERROR (VACOMP-1008): Cannot compile ahdlcmi module library
最后发现应该是一些库文件没有放在正确的位置。通过建立软链接:
sudo ln -s /usr/include/x86_64-linux-gnu/asm /usr/include/asm
sudo ln -s /usr/include/x86_64-linux-gnu/bits /usr/include/bits
sudo ln -s /usr/include/x86_64-linux-gnu/gnu /usr/include/gnu
sudo ln -s /usr/include/x86_64-linux-gnu/sys /usr/include/sys
然后成功解决问题。
发表于 2018-11-9 15:57:21 | 显示全部楼层
有没有跑spectre仿真报错的啊
发表于 2018-11-12 16:49:15 | 显示全部楼层
学习了
发表于 2019-1-25 00:38:36 | 显示全部楼层
回复 1# sendyqq
    你好,我也遇到了一样的问题,请问还记得当时是怎么解决的吗
Internal error found in spectre during AHDL read-in, in `crtmom':`C0', during hierarchy flattening, during circuit read-in.
Encountered a critical error during simulation. Submit a Service Request via Cadence Online Support, including the netlist, the Spectre log file, the behavioral model files, and any other information that can help identify the problem.
    FATAL (SPECTRE-18): Segmentation fault.
IC617+spectre17
发表于 2021-2-1 19:50:07 | 显示全部楼层
1339054284 发表于 2019-1-25 00:38
回复 1# sendyqq
请问你解决问题了嘛?应该怎么解决这个问题呢?谢谢~
发表于 2022-3-25 16:27:51 | 显示全部楼层
回复 1# sendyqq
我用了618然后就可以跑出来,但能不能根治就不知道了
GMT+8, 2025-12-25 21:16 , Processed in 0.028736 second(s), 3 queries , Gzip On, Redis On.
