Error found by spectre during AHDL read-in.
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB//bsource.va.bsource_1.ahdlcmi/Linux/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
ERROR (SFE-91): Error when elaborating the instance bsource_1. Simulation should be terminated.
Internal error found in spectre during AHDL read-in, in `PM5.ressppoly_rg':`PM4.xrg', in `gpdk045_pmos2v':`PM4', during hierarchy flattening, during circuit read-in.
Encountered a critical error during simulation. Submit a Service Request via Cadence Online Support, including the netlist, the Spectre log file, the behavioral model files, and any other information that can help identify the problem.
FATAL (SPECTRE-18): Segmentation fault.
以上是spectre.out 上显示的错误报告,用MMSIM10.1做仿真的时候完全没有问题的,换成MMSIM12.1的时候就提示错误了!系统是Centos6.3。有人遇到这个问题吗?求解决方法!谢谢! |
