楼主: sendyqq
[求助] Cadence IC 615用MMSIM12.1仿真出现Error found by spectre during AHDL read-in.
发表于 2014-1-3 08:35:59 | 显示全部楼层
回复 1# sendyqq
   设置 setenv CDS_AHDLCMI_ENABLE  yes    后面得yes如果小写不行……就用大写……我得是写大写不行……只能小写
发表于 2014-1-3 11:01:15 | 显示全部楼层
回复 1# sendyqq
    切换32位Spectre到64位,或反之,试试看。
发表于 2014-4-16 08:31:50 | 显示全部楼层
在用64位的MMSIM12
时,出错
/lib64/libc.so.6: version `GLIBC_2.14' not found (required by /home/cadence/MMSIM12/tools.lnx86/lib/64bit/SuSE/libelf.so.1)
32位没有问题!
求帮助64位
发表于 2014-4-16 09:25:03 | 显示全部楼层
Please install glibc-devel
the command : yum install glibc-devel
than re-start your linux.
I hope it can help you.
mpig
发表于 2014-4-16 09:57:47 | 显示全部楼层
回复 14# mpig09
   谢谢,朋友我的是RHEL6.4 64位系统,好像那个指令有问题
[dandeng@danwork ~]$ yum install glibc-devel
Traceback (most recent call last):
  File "/usr/bin/yum", line 28, in <module>
    import yummain
  File "/usr/share/yum-cli/yummain.py", line 32, in <module>
    from yum.i18n import to_unicode, utf8_width, exception2msg
ImportError: cannot import name exception2msg
发表于 2014-4-16 11:50:34 | 显示全部楼层
Hi dandeng:
Thanks for your reply.
Does this problem solve?
mpig
发表于 2014-4-16 12:12:52 | 显示全部楼层
Hi dandeng:
Does the problem solve?
mpig
发表于 2014-4-16 13:36:09 | 显示全部楼层
我的6.4的系统也经常出问题,现在都是切到别的机器上用
发表于 2014-6-24 20:00:25 | 显示全部楼层
Error found by spectre during circuit read-in.
    ERROR (SFE-396): "/home/ZZW/PDK/GPDK/gpdk045_v3.5/gpdk045/../models/spectre/gpdk045_resistor.scs" 1146: Model `ndio' has already been defined.
    ERROR (SFE-396): "/home/ZZW/PDK/GPDK/gpdk045_v3.5/gpdk045/../models/spectre/gpdk045_resistor.scs" 1164: Model `pdio' has already been defined.
    ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB/bsource_1.input.ahdlcmi/Linux2.6.18-194.el5+gcc/../ahdlcmi.out for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
Warning from spectre in `i1.m1.ressnpoly_rg':`i1.m1.xrg', in `g45n1hvt':`i1.m1', in `int_schematic':`i1', during hierarchy flattening.
    WARNING (SFE-30): "/home/ZZW/PDK/GPDK/gpdk045_v3.5/gpdk045/../models/spectre/gpdk045_mos.scs" 51390: i1.m1.xrg.r1: `temp' is not a valid parameter for an instance of `bsource_1'.  Ignored.
    WARNING (SFE-30): "/home/ZZW/PDK/GPDK/gpdk045_v3.5/gpdk045/../models/spectre/gpdk045_mos.scs" 51390: i1.m1.xrg.r1: `tnom' is not a valid parameter for an instance of `bsource_1'.  Ignored.
    WARNING (SFE-30): "/home/ZZW/PDK/GPDK/gpdk045_v3.5/gpdk045/../models/spectre/gpdk045_mos.scs" 51390: i1.m1.xrg.r1: `bs_par_0' is not a valid parameter for an instance of `bsource_1'.  Ignored.
    WARNING (SFE-30): "/home/ZZW/PDK/GPDK/gpdk045_v3.5/gpdk045/../models/spectre/gpdk045_mos.scs" 51390: i1.m1.xrg.r1: `bs_par_1' is not a valid parameter for an instance of `bsource_1'.  Ignored.
    WARNING (SFE-30): "/home/ZZW/PDK/GPDK/gpdk045_v3.5/gpdk045/../models/spectre/gpdk045_mos.scs" 51390: i1.m1.xrg.r1: `bs_par_2' is not a valid parameter for an instance of `bsource_1'.  Ignored.
什么原因啊???
发表于 2014-9-12 21:03:22 | 显示全部楼层
谢谢楼主分享资料  收下了
GMT+8, 2025-12-25 19:19 , Processed in 0.017846 second(s), 3 queries , Gzip On, Redis On.
