楼主: rfham
[求助] ic615 InstallScape 04.11.s03 version problem
发表于 2013-12-22 15:39:39 | 显示全部楼层
Guys, i also meet the same problem.
And i can't find any solution Can you help me?
发表于 2013-12-30 11:22:40 | 显示全部楼层
Hi buddies,
easy to solve, don't worry.
first check your extraction directory path, DOESN'T  exist any SPACE in the your path and folder names, because function "java -jar -classpath .... " in bashrc is sensitive to space  in directory name. check your path by "pwd" command on terminal. change space in folder name to underline like: IC Tools --> IC_Tools
then check java is installed on your machine, if not, run command in root privilege: yum install java
enjoy it
发表于 2014-1-1 16:03:39 | 显示全部楼层
回复 1# rfham
   can i know which os and version is compatible for cadence
发表于 2014-2-10 01:52:26 | 显示全部楼层
楼主找到了分享一下哦
发表于 2014-5-29 10:38:52 | 显示全部楼层
Same problem faced... just remove the spaces in your path as suggested ... its working..!!!!
发表于 2014-6-24 19:29:48 | 显示全部楼层
感謝8F會友提供的網址....
发表于 2014-9-21 10:27:19 | 显示全部楼层
搞不懂 有没有详细步骤解决
刚接触这系统和软件
发表于 2015-1-17 09:38:38 | 显示全部楼层
这个怎么解决啊
发表于 2015-4-21 16:58:15 | 显示全部楼层
回复 15# spdtechie
这个好像没有用?
发表于 2015-6-15 09:41:05 | 显示全部楼层
回复 8# tpiee
   你好这个iscape下载的115网盘帐号和密码不对嘛。你能提供一下吗。谢谢了,我现在也遇到这个platform问题了。急求。谢谢了
GMT+8, 2025-12-21 21:13 , Processed in 0.020912 second(s), 5 queries , Gzip On, Redis On.
