查看: 24731|回复: 28
[求助] ic615 InstallScape 04.11.s03 version problem
发表于 2013-2-20 22:05:10 | 显示全部楼层 |阅读模式
in the process of installation, when use the installscape to load the local directory/media
then in the terminal display some information like this:
com.khanpur.installerng.ISInstallScapeVersionException: This release can only be installed with InstallScape 04.21.b01 or higher.
You are using InstallScape 04.11.s03. Download the latest version of InstallScape and try again.
where can i find the latest version of InstallScape?  Please give some advice, thank you!
发表于 2013-2-21 09:11:34 | 显示全部楼层
 楼主| 发表于 2013-2-21 19:09:54 | 显示全部楼层
use the link resoure, iscape.04.21-p004 and add the path =...iscape.04.21-p004/bin to "bashrc" then
wl@ubuntu:~/eda/iscape.04.21-p004/bin$ ./iscape.sh
The installed InstallScape is not for the LNX86 platform.
Please use the InstallScape for LNX86 platform.
Exiting...
some thing wrong?
 楼主| 发表于 2013-2-26 16:46:22 | 显示全部楼层
Problem has been solved
发表于 2013-4-25 00:55:03 | 显示全部楼层
thanx
发表于 2013-4-29 20:15:53 | 显示全部楼层
I have the same problem.
Can you tell me how to solve it ?
thanks!
发表于 2013-5-9 23:10:18 | 显示全部楼层
回复 3# rfham
I also met the same problem.
would you please show me how to fix it?
发表于 2013-8-7 23:25:36 | 显示全部楼层
回复 7# Amare.liu
i have meet the same problem,and i down the new from http://bbs.eetop.cn/viewthread.php?tid=339265&highlight=cadence%2B%D7%EE%D0%C2    , and Extract it, run the "iscape.sh", and you will see it.
发表于 2013-9-24 12:43:54 | 显示全部楼层
发的撒快乐啦啦啦啦啦啦啦啦啦啦啦啦
发表于 2013-10-30 11:44:02 | 显示全部楼层
Also met the same problem.
How to solve it?
GMT+8, 2025-12-21 18:32 , Processed in 0.019997 second(s), 5 queries , Gzip On, Redis On.
