查看: 1967|回复: 0
[原创] adc0808仿真代码
发表于 2013-1-31 16:37:00 | 显示全部楼层 |阅读模式
  1. #include <reg52.h>#include <intrins.h>#define ad_con P2#define addata P0#define disdata P1#define uchar unsigned char#define uint unsigned  intuchar number=0x00;sbit ALE=P2^3;sbit START=P2^4;sbit OE=P2^5;sbit EOC=P3^7;sbit KEY1=P3^5;sbit KEY2=P3^6;sbit DISX=disdata^7;sbit FLAG=PSW^5;
  2. uchar code dis_7[11]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77}; uchar code scan_con[4]={0xfe,0xfd,0xfb,0xf7}; uchar data ad_data[8]= {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};uint data dis[5]={0x00,0x00,0x00,0x00,0x00};
  3. void delay1ms(uint t)  {        uint i,j;          for (i=0;i<t;i++)                 for (j=0;j<120;j++);  }
  4. void keytest()  {          if (KEY1==0)        {                FLAG=!FLAG;                while(KEY1==0);          }          if(FLAG==1)        {                if(KEY2==0)                   {                        number++;                     if(number==8)                            {                                number=0;                         }                       while(KEY2==0);                   }               }  }
  5. void scan()  {             uchar k,n;             int h;             if(FLAG==0)           {                       dis[3]=0x00;                     for(n=0;n<8;n++)                     {                                 dis[2]=ad_data[n]/51;                      dis[4]=ad_data[n]%51;                             dis[4]=dis[4]*10;                             dis[1]=dis[4]/51;                             dis[4]=dis[4]%51;                             dis[4]=dis[4]*10;                             dis[0]=dis[4]/51;                     for(h=0;h<500;h++)                           {                                           for(k=0;k<4;k++)                                   {                                         disdata=dis_7[dis[k]];                                      if(k==2)                                          {                                                 DISX=1;                                         }                                      P3=scan_con[k];                                         delay1ms(1);                                         P3=0xff;                                    }                          }                         dis[3]++;                               keytest();                    }             }             if(FLAG==1)             {                     dis[3]=number;             dis[2]=ad_data[n]/51;             dis[4]=ad_data[n]%51;                dis[4]=dis[4]*10;                 dis[1]=dis[4]/51;                 dis[4]=dis[4]%51;                 dis[4]=dis[4]*10;                 dis[0]=dis[4]/51;                 for(k=0;k<4;k++)                 {                               disdata=dis_7[dis[k]];                               if(k==2)                          {                                 DISX=0;                         }                               P3=scan_con[k];delay1ms(1);P3=0xff;                     }                     keytest();         } }
  6. void test()    {             uchar m;                uchar s=0x00;          ad_con=s;        for(m=0;m<8;m++)             {                                      START=1;_nop_();_nop_();START=0;                  _nop_();_nop_();_nop_();_nop_();                             while(EOC==0);                    OE=1;ad_data[m]=addata;OE=0;                   s++;ad_con=s;             }             ad_con=0x00; }
  7. main()    {             P0=0xff;     P2=0x00;             P1=0xff;             P3=0xff;             while(1)                 {                test();                  scan();                }}
    复制代码
GMT+8, 2025-12-26 10:40 , Processed in 0.017189 second(s), 6 queries , Gzip On, Redis On.
