楼主: kuxuanxinzai
[求助] 难道没有什么好的办法在spectre中查看较大的波形文件?
发表于 2013-2-23 18:32:42 | 显示全部楼层
Hi kuxuanxinzai:
I check my simulation result folder, the waveform type is *.tran.
But I can't find any setting to set in my ADE environment.
So, I am sorry I can't help you.
 楼主| 发表于 2013-2-25 10:23:00 | 显示全部楼层
回复 21# mpig09
    非常感谢你的回复,我再找找。。。找到了,我会在帖子中更新的
发表于 2013-2-25 15:23:12 | 显示全部楼层
用sandwork
发表于 2013-2-25 21:14:43 | 显示全部楼层
回复 22# kuxuanxinzai
   Thanks for your kindly sharing.
发表于 2013-2-26 13:56:54 | 显示全部楼层
add following lines in your c-shell files
setenv PSF_WRITE_CHUNK_MODE_ON true
setenv PSF_LARGE_FILE_ON false
发表于 2013-12-5 08:37:48 | 显示全部楼层
Hi kuxuanxinzai :
If you didn't solve this problem, please add following setting in your .cdsinit and
restart icfb , re-run the simulation:
envSetVal("spectre.envOpts" "simOutputFormat" 'string "psfbin")
then the waveform will be .tran and spice explorer can read it.
mpig
发表于 2013-12-5 09:09:26 | 显示全部楼层
xuexi
发表于 2014-3-21 20:13:57 | 显示全部楼层
回复 18# kuxuanxinzai
用ComosScope就可以打开
发表于 2014-7-29 15:21:28 | 显示全部楼层
波形一直是个大问题
发表于 2014-7-29 16:26:52 | 显示全部楼层
回复 26# mpig09
26楼正解
GMT+8, 2025-12-29 06:26 , Processed in 0.017252 second(s), 3 queries , Gzip On, Redis On.
