查看: 2930|回复: 2
[求助] 请问,在clock tree上的max_fanout violation要如何处理?
发表于 2013-1-18 13:34:56 | 显示全部楼层 |阅读模式
做完cts后,clock上有 Max_fanout的violation,怎样才能修改?客户提供的sdc里面要求的 max_fanout是8,做完cts后的fanout最大的是11.
   而我在ctstch里定义了 maxfanout 为 6 ,比客户的要求还严格,并且放宽了 transition。也使用了optDesing,但是还是无法清除clock上面的max_fanout。
   搜索了论坛里面,关于max_fanout解决方法,好像没有是针对clock的max_fanout.
   请问还有什么方法可以清除clock net上的 max_fanout? 谢谢。
发表于 2013-3-18 10:14:23 | 显示全部楼层
回复 1# even_ryen
    ForceMaxFanout YES
MaxFanout integer
Limits the number of clock buffer fanouts to the number
you specify.
If you specify the MaxFanout statement and the
setCTSMode -useLibMaxFanout true parameter,
CTS uses the worst case constraint specified.
CTS does not support a fanout_load that is not equal
to 1.
Note: CTS considers the MaxFanout statement to be a
soft constraint. CTS will try to meet it, but might need to
make adjustments in order to meet physical constraints.
发表于 2013-3-20 12:26:25 | 显示全部楼层
no money left
GMT+8, 2025-12-22 02:57 , Processed in 0.020824 second(s), 7 queries , Gzip On, Redis On.
