查看: 1931|回复: 1
[求助] DPLL
发表于 2013-1-17 11:46:24 | 显示全部楼层 |阅读模式
请教:
请问这样的DPLL如何实现?谢谢!
“The DPLL is used to run the MPEG-2 decoder without an external VCXO. Only a simple 27.0MHz crystal is
used to synchronise the MPEG decoder to the MPEG encoder. Synchronisation is required to avoid buffer
over- or underflow. The digital PLL functionality is realised in order to insert or remove one eighth of the clock
period (DELTA) of the 391.5MHz. A register defines how often one DELTA will be inserted or removed. This
down counter is running at 65.25MHz and, when it reaches zero, one DELTA will be inserted to the 391.5MHz
clock period or one DELTA will be removed from the clock period.”
发表于 2014-11-19 15:35:51 | 显示全部楼层
learning !!!
GMT+8, 2025-10-28 06:56 , Processed in 0.016618 second(s), 6 queries , Gzip On, Redis On.
