查看: 10965|回复: 19
[求助] 请教encounter中post-mask eco遇到的问题[已解决]
发表于 2013-1-10 14:22:08 | 显示全部楼层 |阅读模式
最初的设计,加入spare cell是采用 create sparemoudle 的方式添加的spare cell
dig.eco.v中只改了一个地方,只添加了一个单元
DEL01BWP7T ECO_cell_1 (//ECO
   .I(n600),//ECO
   .Z(ECO_net_1)//ECO
   );//ECO
//   AOI211D0BWP7T U35 (.A1(n600), //ECO
   AOI211D0BWP7T U35 (.A1(ECO_net_1),
        .A2(n14),
        .B(n42),
        .C(n5),
        .ZN(n8));
而且相应的spare cell 也有这个单元:
 DEL01BWP7T DEL01BWP7T_spr_gate1291 (.I(FE_OFN883_tie_hi_net0));
   DEL01BWP7T DEL01BWP7T_spr_gate1290 (.I(FE_OFN883_tie_hi_net0));
   DEL01BWP7T DEL01BWP7T_spr_gate1289 (.I(FE_OFN883_tie_hi_net0));
   DEL01BWP7T DEL01BWP7T_spr_gate1288 (.I(FE_OFN883_tie_hi_net0));
   DEL02BWP7T DEL02BWP7T_spr_gate1287 (.I(FE_OFN883_tie_hi_net0));
   DEL02BWP7T DEL02BWP7T_spr_gate1286 (.I(FE_OFN883_tie_hi_net0));
   DFCND2BWP7T DFCND2BWP7T_spr_gate1285 (.D(FE_OFN882_tie_lo_net0),
在做post-mask eco时,使用的命令行如下:
coDesign -postMask -modifyOnlyLayers 1:5 -spareCells spr* dig.enc.dat dig dig.eco.v
运行过程中,总是报错:
**ERROR: (SOCSYC-2100):    Instance U_DIG/U_MEDIAN/ECO_cell_1 added but couldn't find spare cell for it.
但可以确定,dig.eco.v网表中新增加的ECO_cell_1的确是sparemodule中存在的单元。但不知道为何就是找不到相应的spare cell去替换。
请有经验的大侠们帮忙分析和解答一下,我的flow中是哪里出了问题?
在eco的过程中,看起来也找到了这个spare cell的:
Specifying instance [spr_15/DEL01BWP7T_spr_gate1291] as spare gate.
Specifying instance [spr_15/DEL01BWP7T_spr_gate1290] as spare gate.
Specifying instance [spr_15/DEL01BWP7T_spr_gate1289] as spare gate.
Specifying instance [spr_15/DEL01BWP7T_spr_gate1288] as spare gate.
Specifying instance [spr_15/DEL02BWP7T_spr_gate1287] as spare gate.
Specifying instance [spr_15/DEL02BWP7T_spr_gate1286] as spare gate.
Specifying instance [spr_15/DFCND2BWP7T_spr_gate1285] as spare gate.
Specifying instance [spr_15/DFCND2BWP7T_spr_gate1284] as spare gate.
Specifying instance [spr_1/AOI222D2BWP7T_spr_gate2] as spare gate.
Specifying instance [spr_1/TIEHBWP7T_spr_gate1] as spare gate.
Specifying instance [spr_1/TIELBWP7T_spr_gate0] as spare gate.
Specified 1397 instances as spare gate.
**WARN: (SOCSYT-6782):  Design has no tie cells so all tie connections will be connected to ground.
因为这里报错,所以后续ecoroute也会报错
#ERROR (NRDB-160) INSTANCE U_DIG/U_MEDIAN/ECO_cell_1 is unplaced. All instances must be placed before routing. Refer to Cadence placer or checkPlace for more information.
请大家指点一下,这种情况是哪里做得不正确!
多谢!
 楼主| 发表于 2013-1-10 14:45:44 | 显示全部楼层
怎么今天发帖子,总是显示不出来呢?奇怪!
 楼主| 发表于 2013-1-10 14:48:20 | 显示全部楼层
自己回复了一下,贴子终于在讨论区里出现了,呵呵。以前都没遇到过这样的情况。
发表于 2013-1-10 14:50:25 | 显示全部楼层
用原來的instance name
並且确认他们在同一个module里面,如果不在的话,要从一个module引线到另一个module
 楼主| 发表于 2013-1-10 14:50:30 | 显示全部楼层
ecoDesign -postMask -modifyOnlyLayers 1:5 -spareCells spr* dig.enc.dat dig dig.eco.v
原帖中漏了写了第一字母“e”
 楼主| 发表于 2013-1-10 14:55:35 | 显示全部楼层
回复 4# 陈涛
首先谢谢陈涛版主!
用原來的instance name
还有以下疑问:
1.是说网表中要做特殊处理吗?我还以为:网表中进行正常改动即可,只要网表中用到的cell是spare cell中有的即可。
2.用原來的instance name  这个具体该定义在哪里?
3.如果不在同一个module里的话,如何从一个module引线到另一个module?怎么实现呢?
多谢版主!
发表于 2013-1-10 15:03:56 | 显示全部楼层
   .I(n600),//ECO
   .Z(ECO_net_1)//ECO
   );//ECO
上面那个单元的名字不能是ECO_cell_1,应该是原来的名字 DEL01BWP7T_spr_gate1291
如果不再同一个module里,要在module上加port,把线连出来,接在一起
再不懂的话,我也没辙了
 楼主| 发表于 2013-1-10 15:16:20 | 显示全部楼层
回复 7# 陈涛
我的理解也是这样:前端直接把要用到的那个spare cell单元,做好相应的连接修改,后端读入,进行eco。
但前端认为,他不用去管具体要用哪个spare cell,直接改动自己想改的地方(只要确保他加入的单元是spare cell里面有的就行),然后我做post-mask eco的时候,工具会自动去映射到相关的就近的spare cell,自动进行替换。
到底实际实现post-mask eco时,应该是怎样的流程呢?
如果前端改网表时真要具体到使用某一个spare cell ,不就很有局限性吗,如何得知它就是距离最近的呢?提前在图中查找定位?而且如果网表中有很多地方都需要替换改动,这么做是不是就很耗时?
发表于 2013-1-10 23:53:42 | 显示全部楼层
可以的,我们一直这么做的,没有问题
发表于 2013-1-11 07:48:28 | 显示全部楼层
不行的话,人工找spare cell改不就好了,
数量不多的话 人工找spare cell 比工具找快
GMT+8, 2025-12-25 10:57 , Processed in 0.129196 second(s), 5 queries , Gzip On, Redis On.
