查看: 2929|回复: 1
[求助] xilinx ise 仿真时遇到一个致命性问题
发表于 2013-1-7 21:24:00 | 显示全部楼层 |阅读模式
ise在进行仿真的时候出现致命性错误,里面提示:One or more environment variables have been detected which affect the operation of the C compiler. These are typically not set in standard installations and are not tested by Xilinx, however they may be appropriate for your system, so the flow will attempt to continue.  If errors occur, try running fuse with the "-mt off -v 1" switches to see more information from the C compiler. The following environment variables have been detected:Number of CPUs detected in this system: 4
翻译了一下:
已检测到一个或多个环境变量,影响操作的C编译器。这些通常是没有设置在标准安装未经测试的赛灵思,但他们可能是适合您的系统,所以流将尝试继续。如果发生错误,请尝试运行“-MT-V关闭”开关,保险丝,看到的C编译器的更多信息。已检测到下面的环境变量:
在该系统中检测到的CPU数目:4
请问大家有什么可以解决的方案吗?
发表于 2013-1-8 09:22:50 | 显示全部楼层
是不是开启了ISE的多核处理功能?
GMT+8, 2025-12-26 23:34 , Processed in 0.012422 second(s), 5 queries , Gzip On, Redis On.
