查看: 14246|回复: 47
VLSI Custom Microelectronics.Digital, Analog, and Mixed-Signal
发表于 2006-12-26 12:30:42 | 显示全部楼层 |阅读模式
VLSI Custom Microelectronics.Digital, Analog, and Mixed-Signal.part1.rar
1.39 MB, 下载次数: 169 , 下载积分: 资产 -2 信元, 下载支出 2 信元
part1
 楼主| 发表于 2006-12-26 12:32:12 | 显示全部楼层
VLSI Custom Microelectronics.Digital, Analog, and Mixed-Signal.part2.rar
740.25 KB, 下载次数: 143 , 下载积分: 资产 -2 信元, 下载支出 2 信元
part2
发表于 2006-12-26 16:45:35 | 显示全部楼层
thanks for your information....
thanks......
发表于 2007-1-5 21:15:31 | 显示全部楼层
thanks
发表于 2007-1-6 01:09:29 | 显示全部楼层
hao shu, ding!!!!!
发表于 2007-1-6 01:21:02 | 显示全部楼层
but i found that it is kind of outdated,  because it is 1998.
发表于 2007-1-24 06:44:45 | 显示全部楼层
回复 #2 real 的帖子
good.
发表于 2007-1-24 08:05:18 | 显示全部楼层
感謝你阿
发表于 2007-1-24 08:37:32 | 显示全部楼层
Preface
Preface
In its short life span, microelectronics has become the most complex of our everyday
technologies, embracing as it does physics, chemistry, materials, thermodynamics,
and micromechanical engineering, as well as electrical and electronic
engineering and computer science. No one person can hope to be expert in all
these diverse aspects.
Yet in spite of all this complexity and sophistication, we often take the end
products for granted. Nowadays, our homes contain tens of thousands of transistors
in domestic appliances, communications, and entertainment equipment, to
add to the vast range of applications in industrial, military, space, and commercial
products. To make all this possible has required the simultaneous evolution of
not only the ability to fabricate the microelectronic circuits themselves, but also
the ability to design them without errors in the first place and to test them appropriately
during and after production.
This is not a text detailing silicon design and fabrication methods. Instead,
it is principally concerned with the important branch of microelectronics dealing
with custom circuits, whereby specific circuit designs required by original equipment
manufacturers can be realized rapidly and economically in possibly small
production quantities. The term application-specific IC (ASIC) has been widely
used up to now, but the more accurate term user-specific IC (USIC) is now increasingly
used. Custom circuits have only become viable with the maturity of
both the circuit fabrication methods and the computer-aided design resources
necessary for their design and test, thus releasing the circuit designer from personal
involvement in the range and depth of detail involved.
发表于 2007-1-24 08:38:19 | 显示全部楼层
However, having said this, it is the hallmark of a good engineer to be aware
of all the aspects involved even though he or she may not need—or indeed, not
be able—to do anything about them. This text adopts this approach, and attempts
to give a comprehensive overview of all aspects of custom electronics, including
the very important but difficult managerial decisions of when or when not
to use it.
The concept of custom microelectronic circuits is not new; it has been
almost three decades since its simple conception, but it probably did not achieve
very great prominence until the early 1980s. The introduction of the microprocessor
as a readily available standard off-the-shelf part delayed the wider adoption
of custom microelectronics and still is a major force in all the initial ‘‘howshall-
we-make-it’’ product design decisions. Nevertheless, custom ICs offer their
particular technical or economic advantages, and every product designer should
be aware of the strengths as well as the weaknesses of both custom and other
design styles. These are the matters we shall consider in the pages of this text.
It is assumed that the reader will be familiar with the principles of microelectronic
devices, semiconductor physics, basic electronic circuits, and system
design as covered in many standard teaching texts. For readers requiring a more
detailed treatment than is given here, specific texts dealing solely with such areas
as device physics, computer-aided design, or other aspects, should be consulted.
Regrettably, no one book (and no one author!) can cover all these aspects in
depth, but it is hoped that the references contained in these pages will point to
such additional in-depth information.
The principles of custom microelectronics are now well established, but in
common with the whole of the microelectronics industry, there is a continual
evolution in complexity of devices, in obsolescence of particular components and
CAD resources, and in the rise and fall of industrial companies that make up the
custom circuits field. It is therefore inevitable that some of the commercial products
described in this text will no longer continue to represent the status quo, but
the basic educational points being made using these illustrations should remain
valid. It is therefore hoped that this book will enable readers to appreciate the
broad spectrum of custom microelectronics and will serve as an appropriate reference
to whatever newer products and design strategies evolve in this field.
Stanley L. Hurst
TM Copyright n 1999 by Marcel Dekker, Inc. All Rights Reserved.
GMT+8, 2025-12-30 15:36 , Processed in 0.029950 second(s), 7 queries , Gzip On, Redis On.
