查看: 6777|回复: 9
ubuntu ic615问题,求大神
发表于 2012-12-26 21:51:21 | 显示全部楼层 |阅读模式
vincent@ubuntu:~/eda/ic615$ virtuoso:   ERROR: Unrecognized platform.
virtuoso:          Make sure that your current host architecture and OS are
virtuoso:          supported by Cadence for the application: virtuoso.
virtuoso:          If you contact your Cadence representative, please provide the
virtuoso:          following information:
virtuoso:              - cds_plat returned:
virtuoso:                  /home/vincent/eda/ic615/tools/dfII/bin/virtuoso[78]: .[680]: /home/vincent/eda/ic615/tools/bin/cds_plat: not found [No such file or directory]
virtuoso:              - on platform: Linux ubuntu 2.6.38-16-generic #67-Ubuntu SMP Thu Sep 6 18:00:43 UTC 2012 i686 i686 i386 GNU/Linux
这个是不是代表这个版本不能用?
发表于 2012-12-26 22:00:48 | 显示全部楼层
在你的终端上键入cds_plat,看看什么输出?
 楼主| 发表于 2012-12-26 22:04:50 | 显示全部楼层
bash: /home/vincent/eda/mmsim111/tools/bin/cds_plat: /bin/csh: bad interpreter: No such file or directory
发表于 2012-12-26 22:06:59 | 显示全部楼层
要安装csh
sudo apt-get install csh
 楼主| 发表于 2012-12-26 22:18:35 | 显示全部楼层
这个字体怎么修改?
 楼主| 发表于 2012-12-26 22:22:41 | 显示全部楼层
无标题.png 这个字体怎么修改?
发表于 2012-12-27 00:08:37 | 显示全部楼层
you can install x11 font + xorg font
you have very problem with ubuntu (ADEGLX not work correct )
i offer to you use centos 6 with installed (
xorg-x11-fonts-ISO8859-1-100dpi-7.2-9.1.el6.noarch.rpm - A set of 100dpi ISO-8859-1 fonts for X.
xorg-x11-fonts-ISO8859-14-100dpi-7.2-9.1.el6.noarch.rpm - ISO8859-14-100dpi fonts
xorg-x11-fonts-ISO8859-14-75dpi-7.2-9.1.el6.noarch.rpm - ISO8859-14-75dpi fonts
xorg-x11-fonts-ISO8859-15-100dpi-7.2-9.1.el6.noarch.rpm - ISO8859-15-100dpi fonts
xorg-x11-fonts-ISO8859-15-75dpi-7.2-9.1.el6.noarch.rpm - ISO8859-15-75dpi fonts
xorg-x11-fonts-ISO8859-1-75dpi-7.2-9.1.el6.noarch.rpm - A set of 75dpi ISO-8859-1 fonts for X.
xorg-x11-fonts-ISO8859-2-100dpi-7.2-9.1.el6.noarch.rpm - A set of 100dpi Central European language font
) package or use mandriva or mageia instead debian ubuntu mint and fedora
发表于 2012-12-27 10:50:45 | 显示全部楼层
xfonts-75dpi
 楼主| 发表于 2012-12-27 21:00:32 | 显示全部楼层
已经解决,谢谢大家
发表于 2014-7-31 22:02:54 | 显示全部楼层
已经解决,谢谢大家
ccp106 发表于 2012-12-27 21:00
请问你当时怎么解决这个问题的啊?我现在遇到这个问题了,很困惑啊,希望你能指导一下
GMT+8, 2025-12-21 18:49 , Processed in 0.021891 second(s), 6 queries , Gzip On, Redis On.
