查看: 3317|回复: 2
[求助] 有用过SMIC130nm的朋友吗?我用assura做LVS报错了。
发表于 2012-12-26 16:04:23 | 显示全部楼层 |阅读模式
诸如:warn:   Undefined layer in dfII.
Layer name 'M1SLOT' doesn't exist, treating as an empty layer.
M1 = layer("M1" "M1DUM" "M1SLOT" type("drawing"))
Layer name 'M2SLOT' doesn't exist, treating as an empty layer.
M2 = layer("M2" "M2DUM" "M2SLOT" type("drawing"))
warn:   First input layer of 'as = measureParameter(area (ndiff) 1e-12)' should be a device terminal or recognition layer due to the correspondent 'attachParameter(as ("ad" "D") ("as" "S") ngat12_rec shared)' being a terminal specific case.
If left unchanged, parameters may not be attached correctly.
   795. attachParameter(as ("ad" "D") ("as" "S") ngat12_rec shared)
还有:
error:  Illegal calculate item 'if((G == 1) then (turns_c - 1) else (turns_c - 1.5))' found in calculateParameter().
  2460. turns = calculateParameter(if((G == 1) then (turns_c - 1) else (turns_c - 1.5)))
error:  nameParameter command cannot be used due to the wrong derived layers in calculateParameter command. 'turns'.
  2467. nameParameter(turns "n")
error:  Illegal calculate item 'if(((D / E) == 2) then (E + 0.5) else (E + 1))' found in calculateParameter().
  2476. turns = calculateParameter(if(((D / E) == 2) then (E + 0.5) else (E + 1)))
  2483. nameParameter(turns "n")
谢谢大家!
发表于 2013-4-17 15:57:40 | 显示全部楼层
rerererer
发表于 2013-6-27 12:34:44 | 显示全部楼层
语言格式不正确   我用smic013中也遇到电感的问题
GMT+8, 2025-12-28 21:52 , Processed in 0.017136 second(s), 6 queries , Gzip On, Redis On.
