发表于 2012-12-22 12:19:04
显示全部楼层
OPT-207
NAME
OPT-207 (Warning) The multiple port net %s is not fixed by MPN.
DESCRIPTION
This warning message occurs when MPN fixes a multiple port net, it finds the net is located at top level and the variable ’compile_no_new_cells_at_top_level’ is set as true.
In most abutted designs, the variable ’compile_no_new_cells_at_top_level’ need be set as true when there is no empty space in top level . Otherwise, the new cells might be added to top by optimization and cause legalization failure.
By default, the variable is false and new buffer will be inserted to fix the multiple port net.
WHAT NEXT
For this case, it suggests user to mannually fix the multiple port net by revising the input design. |
