楼主: half_honey
[求助] icc insert_pad_filler【已解决】
发表于 2014-2-14 09:46:32 | 显示全部楼层
楼主后来这个问题怎么解决的?
 楼主| 发表于 2014-2-14 12:09:03 | 显示全部楼层
回复 11# snoopygaoq
   见1楼
发表于 2014-2-19 16:30:35 | 显示全部楼层
发表于 2014-3-1 22:49:12 | 显示全部楼层
please try to insert the pad filler step by step.
1. add the whole pad zone
2. delete the unused zone and insert the new different pad filler again
hope you get a good result
发表于 2014-3-1 22:49:52 | 显示全部楼层
BTW, Do you found any route guide for it?
发表于 2014-3-2 21:12:20 | 显示全部楼层
插pad filler一般不加bbox吧????
发表于 2014-11-23 12:26:35 | 显示全部楼层
谢谢           !
发表于 2020-3-22 12:06:39 | 显示全部楼层
想请教一下pad的填充单元怎么选
GMT+8, 2025-10-8 08:34 , Processed in 0.018178 second(s), 3 queries , Gzip On, Redis On.
