查看: 3473|回复: 2
[求助]给出IQ两路求幅角,请教!
发表于 2006-6-19 10:28:29 | 显示全部楼层 |阅读模式
偶想用xinlinx ise 中的 cordic 实现求幅角 ,输入为I,Q两路,但是看不懂它的输入数据的格式,这是怎么转换的呢?我的数据是2的补码形式的,怎么样才能使用这个ipcore?  另外不用这个方法的话,还有什么招可以求幅角的?请指点
The input vector (Xin, Yin) is expressed as a pair of signed 1QN numbers. The output angle, Pout radians, isexpressed as a signed 2QN number. In this example, the input/output width is set to 10 bits.
Xin : .0010100000. => 00.10100000 => 0.625
Yin : .0010000000. => 00.10000000 => 0.500
Pout : .0001010110. => 000.1010110=> 0.672
1QN Format Data
SB D8 D7 D6 D5 D4 D3 D2 D1
+1 0 1 0 0 0 0 0 0 0
-1 1 1 0 0 0 0 0 0 0
+Pi/4 0 0 1 1 0 0 1 0 0
-Pi/4 1 1 0 0 1 1 0 1 1
^ <---Binary Point
2QN Format Phase
+1 0 0 1 0 0 0 0 0 0
-1 1 1 1 0 0 0 0 0 0
+Pi 0 1 1 0 0 1 0 0 1
-Pi 1 0 0 1 1 0 1 1 1
^ <---Binary Point
In 2Q10 format values, +Pi and -Pi, are represented:
"01100100100" => 011.00100100 => +3.14
"10011011100" => 100.11011100 => - 3.14
 楼主| 发表于 2006-6-22 09:58:19 | 显示全部楼层
[求助]给出IQ两路求幅角,请教!
ding
发表于 2006-6-24 22:13:50 | 显示全部楼层
GMT+8, 2025-12-25 09:35 , Processed in 0.017939 second(s), 6 queries , Gzip On, Redis On.
