查看: 2213|回复: 1
[求助] CYCLONEII_SAFE_WRITE 设定无效?
发表于 2012-12-4 16:34:50 | 显示全部楼层 |阅读模式
Error (176029): Memory block
**********altsyncram:altsyncram_component|altsyncram_v882:auto_generated|ram_block1a0 uses a global signal on its clock-enable1 port.  This is not allowed for this family.
参数设置(SETTINGS_DEFAULT PA**ETERS)中添加一个名(NAME)为 CYCLONEII_SAFE_WRITE、值(DEFAULT SETTING)为VERIFIED_SAFE的参数
 楼主| 发表于 2012-12-4 18:13:06 | 显示全部楼层
Memory block <name> uses a global signal on its clock-enable1 port. This is not allowed for this family.
(ID: 176029)
CAUSE:         Design contains one or more memory blocks that use a global signal on the clock-enable1 port of the RAM and there is not legal routing support for this configuration.
ACTION:         Change the signal source of the clock-enable1 port to use no control signal or a non-global control signal.
GMT+8, 2025-12-17 09:26 , Processed in 0.020690 second(s), 5 queries , Gzip On, Redis On.
