查看: 6792|回复: 3
[求助] verilog/VCS 模块加密
发表于 2012-11-29 11:16:14 | 显示全部楼层 |阅读模式
有谁知道verilog/VCS模块加密的方法啊?
发表于 2012-11-29 13:41:06 | 显示全部楼层
You can use VCS to encrypt selected parts of your source files. In order to achieve this, complete the following steps:
1. Enclose the Verilog code that you want to encrypt between the
‘protect128 and the ‘endprotect128 compiler directives.
Enclose the VHDL code that you want to encrypt between the
--protect128 and --endprotect128 pragmas.
2. Analyze the files with the -protect128 option. For example:
% vlogan -protect128 foo.v
% vcs -protect128 foo.v
发表于 2012-11-30 22:34:01 | 显示全部楼层
这个牛叉啊
发表于 2014-3-11 10:28:07 | 显示全部楼层
回复 2# wujie828
   大侠请问:
        我有个.vp文件(`protected ... `endprotected)用NC-verilog可以编译和仿真,但在VCS中报错:
                   Error-[BE] Bad encryption
                       Started encryption outside a module or in another scope.
        请问这是为啥么?
GMT+8, 2025-9-19 11:13 , Processed in 0.014198 second(s), 5 queries , Gzip On, Redis On.
