查看: 5329|回复: 9
[求助] VCS装好怎么又不行了?
发表于 2012-11-20 19:36:33 | 显示全部楼层 |阅读模式
昨天按照eetop的教程将VCS装好了,VCS和dve都能使用,晚上再打开却报错Cannot connect to the license server.
The connect() system call failed.
Make sure that your SNPSLMD_LICENSE_FILE is pointing to the right
location and that the license server is up.
Retrying request.....
Failed to obtain license...
Note: Use +vcs+lic+wait ( or -licwait <minute> or -licqueue  in Unified Use Model ) to queue for license
我记得是按照教程处理好SNPSLMD的,各位大侠求帮助啊。
我用的是虚拟机装的ubuntu10
 楼主| 发表于 2012-11-21 20:27:39 | 显示全部楼层
不知道怎么启动啊,我装好一重启或者挂起再开机就不行了,提示上面的错误,还请给详细说说
发表于 2012-11-22 16:35:29 | 显示全部楼层
Everytime you wanna start your soft, you should start the lic server first!
you can add it in a shell file!
发表于 2012-11-23 15:26:46 | 显示全部楼层
licence启动错误
发表于 2014-1-21 16:46:00 | 显示全部楼层
在license的server的下一行添加如下字段(/usr/synopsys/scl/linux/bin是scl安装好的目录)
VENDOR snpslmd /usr/synopsys/scl/linux/bin
发表于 2014-7-25 14:15:14 | 显示全部楼层
license 的server在哪??
发表于 2014-8-8 18:16:01 | 显示全部楼层
Need solution for that.
发表于 2016-7-2 09:52:22 | 显示全部楼层
运行lmli2
GMT+8, 2025-12-17 06:41 , Processed in 0.033609 second(s), 5 queries , Gzip On, Redis On.
