查看: 1970|回复: 1
[求助] 请问 这个DCM约束出错是啥原因?
发表于 2012-10-23 23:37:30 | 显示全部楼层 |阅读模式
输入10M精致,DCM倍频22倍,par 时序出错信息:
Asterisk (*) preceding a constraint indicates it was not met.
   This may be due to a setup or hold violation.
  Constraint                                |    Check    | Worst Case |  Best Case | Timing |   Timing
                                            |             |    Slack   | Achievable | Errors |    Score
* TS_dcm_clkfx = PERIOD TIMEGRP "dcm_clkfx" | SETUP       |    -8.458ns|    13.003ns|    7061|     4275927
   TS_clk_ex / 22 HIGH 50%                  | HOLD        |     0.296ns|            |       0|           0
  TS_clk_ex = PERIOD TIMEGRP "clk_ex" 100 n | MINLOWPULSE |    68.000ns|    32.000ns|       0|           0
  s HIGH 50%                                |             |            |            |        |
发表于 2012-10-25 08:18:01 | 显示全部楼层
貌似是你的设计到不了220Mhz。
GMT+8, 2025-12-22 19:19 , Processed in 0.011648 second(s), 3 queries , Gzip On, Redis On.
