查看: 2911|回复: 2
[求助] 【求助】关于check_physical_design
发表于 2012-10-9 21:16:58 | 显示全部楼层 |阅读模式
小生研一菜鸟一只,刚接触ICC,学的是一头雾水,请各位大虾多指点我啊。
我在做placement的setup和check这一步的时候,输入标题中的命令,报了3个errors,分别的是PSYN-1072和PSYN-1082,我man了之后,
NAME
       PSYN-1027  (warning)  Ordered list checking failed in chain - %s. There
       are %d excessive cells in the SCANDEF:
DESCRIPTION
       When an ordered list is checked, some scan cells specified in the SCAN-
       DEF are not found in the netlist accordingly.
       This inconsistency will not affect the DFT optimization, but the source
       of the inconsistency should be investigated.
WHAT NEXT
       You need to check both the SCANDEF and netlist to make them consistent.
NAME
       PSYN-1082 (error) A serious error (%s) has occurred. Aborting.
DESCRIPTION
       A  serious error has occurred. The current command and script have been
       aborted.
其中1072出现了两次,对于1072的那个错误我读的不是很懂,大概是不是说DEF的时候出现问题了,然后后面告诉我需要检查SCANDEF和NETLIST,使他们一致,请问这里应该怎么解决啊??
 楼主| 发表于 2012-10-9 22:16:31 | 显示全部楼层
我自己解决了,原因是没有读入scandef文件
发表于 2013-7-27 05:39:41 | 显示全部楼层
嗯,是的
GMT+8, 2025-12-23 01:18 , Processed in 0.017568 second(s), 5 queries , Gzip On, Redis On.
