查看: 3738|回复: 4
[原创] How to change from NGSpice to HSpice
发表于 2012-9-19 13:52:46 | 显示全部楼层 |阅读模式
Here examples shall be used to explain change in syntax from NGSpice to HSpice.
After reading this topic one shall be comfortable with programming HSpice.
Please wait, i shall be uploading programs shortly with detailed explanation.
Hope this helps.
Note:- This topic has been created by keeping in mind beginners.
 楼主| 发表于 2012-9-19 14:40:21 | 显示全部楼层
As seen in 1_cmos_inv.rar files,
Give, is an simple example of CMOS_inv to find vol,voh,vil,vih and max. Power
1)Main difference in Ngspice and Hspice is that,
NGSPICE= requires you to use .control followed by run to execute and see results
HSPICE= remember to remove the .control block
1_cmos_inv.rar
624 Bytes, 下载次数: 9 , 下载积分: 资产 -2 信元, 下载支出 2 信元
1
 楼主| 发表于 2012-9-19 17:54:45 | 显示全部楼层
These are jpg's explaining basic parameter extraction from graph.i.e basically what must see.
If any doubts please fell free to ask.
simulations_of_1_cmos_inv.rar
184.41 KB, 下载次数: 11 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2012-9-19 20:48:05 | 显示全部楼层
For running NGSpice on windows pleasei) download NgSpice_24_windows.rar---also freely available on sourgeforge.net
ii) install Microsoft visual studio
Then go in  NgSpice_24_windows> bin >>click ngspice
NGSpice_24_windows.rar
3.92 MB, 下载次数: 54 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Open-source software
发表于 2013-2-13 02:44:52 | 显示全部楼层
is hspice opensource?? if yes its good ..it should be .then good
GMT+8, 2025-12-30 03:00 , Processed in 0.020886 second(s), 6 queries , Gzip On, Redis On.
