查看: 3002|回复: 3
[求助] astro在plancement的时候,软件会在Freeing allreference libraries显示之后无故关掉?
发表于 2012-9-10 11:53:33 | 显示全部楼层 |阅读模式
初始觉得是core利用率太高,后来都调到60%了,还是这个结果,求帮助,谢谢!!!提示如下:
Freeing allreference libraries显示之后,软件退出,无结果保留
PRO: Core utilization: 63.171
CDC: initializing coupling map ...
CDC: will use placement congestion map only
CDC: using Placement congestion map
CDC: coupling map initialized successfully.
EK: max routing layer: 3
EK: there are -1 variable routing rules
VDD Domain 0:
PRO: Buffers selected for setup and holdoptimization:
L111  F111  F112  F153  F131  F154  F132  F158
PRO: Extra buffers selected for holdfixing:
PRO: Inverters selected for setup and holdoptimization:
L101 Y101  F101  F102  F143  F144  F148
PRO: Buffers selected for design rulefixing:
F158  F154  F153  F112  F111  L111  F131  F132
PRO: Inverters selected for design rulefixing:
F148  F143  F144  F102  F101  L101  Y101
caught signal 11 [segmentation violation].
Freeing CG (Common Graph) of top cell(top_setup.CEL;2) (ID = 3)
CGHIER: total nets=0
       flat=0hier=0
       fixed=0unchanged=0
CGHIER: +++ Checking for HCG and flat CGconsistency ... +++
CGHIER: +++ Done with checking HCG and flatCG consistency. +++
CGHIER: Number of errors = 0
* Mon Sep 10 09:38:13 2012
* Overlap Removal- Quasi (OVQ) EngineTerminated
CDC: existing placement coupling map freed
VR: Virtual Routing Completed
Freeing all reference libraries
 楼主| 发表于 2012-9-10 12:36:26 | 显示全部楼层
求救啦,紧急,顶起!
发表于 2012-9-10 16:47:30 | 显示全部楼层
遇到过,只要涉及timing的运算都会在Freeing all reference libraries
后退出,后来在别的机器(装的系统不同,软件一样)可以正常运行
 楼主| 发表于 2012-9-10 17:40:57 | 显示全部楼层
回复 3# jinglingmao
   谢谢!那就是说在这个系统下无法跑了么?可能原因是内存不足,或者什么的?反正就是系统的一些配置使得软件跑不下去了?这可就悲剧了,我们是在ICC公共平台上跑的。。。
GMT+8, 2025-12-21 15:28 , Processed in 0.017873 second(s), 6 queries , Gzip On, Redis On.
