查看: 5619|回复: 7
[求助] Nanosim,HSIM与VCS混仿环境设置问题
发表于 2012-8-27 01:58:29 | 显示全部楼层 |阅读模式
I was run thru with the mixed signal simulation in the shipped example, but get the following error.
Error-[MSV-NANOSIM-VCS] Could not find NanoSim installation
  Please source <NanoSim_install_dir>/<CSHRC_ns> before compilation.
Actually, nanosim and vcs both work fine separately. And I believe the env setting in the .bashrc is correct.
So I wonder if anyone can give me some hints on solving this problem.
Thanks very much in advance.
BTW, the cosim between VCS and HSIM is pretty the same thing. And the similar error is as follows.
Error-[MSV-HSIM-VCS] Could not find HSIM installation
  Please set <HSIM_install_dir>/bin in the path before compilation.
发表于 2013-2-18 20:01:05 | 显示全部楼层
by pass!!1
发表于 2014-4-15 12:26:13 | 显示全部楼层
好东西,顶
发表于 2014-8-29 11:19:36 | 显示全部楼层
非常不错,必须赞一个
发表于 2014-9-10 21:44:31 | 显示全部楼层
感谢分享,谢谢。
发表于 2015-9-3 07:13:36 | 显示全部楼层
setenv NANOSIM /.../...
setenv HSIM /.../...
发表于 2016-8-30 13:53:16 | 显示全部楼层
非常不错 赞一个
发表于 2016-9-9 18:54:46 | 显示全部楼层
求解我也遇到了
GMT+8, 2025-12-17 08:35 , Processed in 0.027569 second(s), 5 queries , Gzip On, Redis On.
