查看: 31536|回复: 27
[求助] 跑LVS是出现错误bad component subtype
发表于 2012-8-24 22:02:19 | 显示全部楼层 |阅读模式
我在跑LVS是出现这个错误,怎么解决,求大神帮助
                                 INCORRECT INSTANCES
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    X16/C2765(19.435,17.290)  C(mim_1p0)                      XI790/CC0  C(CP)
  2    X16/C2766(27.165,17.290)  C(mim_1p0)                      XI793/CC0  C(CP)
  3    X16/C2767(36.640,17.290)  C(mim_1p0)                      XI781/CC0  C(CP)
  4    X16/C2768(44.370,17.290)  C(mim_1p0)                      XI794/CC0  C(CP)
  5    X16/C2769(53.835,17.290)  C(mim_1p0)                      XI799/CC0  C(CP)
  6    X16/C2770(61.565,17.290)  C(mim_1p0)                      XI797/CC0  C(CP)
  7    X16/C2771(71.040,17.290)  C(mim_1p0)                      XI800/CC0  C(CP)
  8    X16/C2772(78.770,17.290)  C(mim_1p0)                      XI787/CC0  C(CP)
  9    X16/C2773(88.230,17.290)  C(mim_1p0)                      XI798/CC0  C(CP)
10    X16/C2774(95.960,17.290)  C(mim_1p0)                      XI796/CC0  C(CP)
11    X16/C2775(105.445,17.290)  C(mim_1p0)                     XI808/CC0  C(CP)
12    X16/C2776(113.175,17.290)  C(mim_1p0)                     XI802/CC0  C(CP)
13    X16/C2777(122.635,17.290)  C(mim_1p0)                     XI786/CC0  C(CP)
14    X16/C2778(130.365,17.290)  C(mim_1p0)                     XI807/CC0  C(CP)
15    X16/C2779(139.840,17.290)  C(mim_1p0)                     XI791/CC0  C(CP)
16    X16/C2780(147.570,17.290)  C(mim_1p0)                     XI803/CC0  C(CP)
17    X16/C2781(157.030,17.290)  C(mim_1p0)                     XI789/CC0  C(CP)
18    X16/C2782(164.760,17.290)  C(mim_1p0)                     XI812/CC0  C(CP)
19    X16/C2783(174.240,17.290)  C(mim_1p0)                     XI801/CC0  C(CP)
20    X16/C2784(181.970,17.290)  C(mim_1p0)                     XI811/CC0  C(CP)
21    X16/C2785(191.435,17.290)  C(mim_1p0)                     XI785/CC0  C(CP)
22    X16/C2786(199.165,17.290)  C(mim_1p0)                     XI788/CC0  C(CP)
23    X16/C2787(208.640,17.290)  C(mim_1p0)                     XI782/CC0  C(CP)
24    X16/C2788(216.370,17.290)  C(mim_1p0)                     XI784/CC0  C(CP)
25    X16/C2789(225.835,17.290)  C(mim_1p0)                     XI795/CC0  C(CP)
26    X16/C2790(233.565,17.290)  C(mim_1p0)                     XI783/CC0  C(CP)
27    X16/C2791(243.040,17.290)  C(mim_1p0)                     XI810/CC0  C(CP)
28    X16/C2792(250.770,17.290)  C(mim_1p0)                     XI806/CC0  C(CP)
29    X16/C2793(260.235,17.290)  C(mim_1p0)                     XI805/CC0  C(CP)
30    X16/C2794(267.965,17.290)  C(mim_1p0)                     XI804/CC0  C(CP)
31    X16/C2795(277.440,17.290)  C(mim_1p0)                     XI809/CC0  C(CP)
32    X16/C2796(285.170,17.290)  C(mim_1p0)                     XI792/CC0  C(CP)
我原理图中用的是mim_1p0,不知道怎么该,求大神,谢谢
发表于 2012-8-25 08:32:18 | 显示全部楼层
两种方法,一种是你改线路模型名字将mim_1p0改成CP,或是改lvs文件将里提取器件的模型名CP改成mim_1p0。
发表于 2012-8-25 09:23:40 | 显示全部楼层
就是电容种类出错了啊!
发表于 2012-8-27 15:58:26 | 显示全部楼层
电容的类型没有匹配上,如果你确定layout没问题的话。在cdl上加上
.EQUIV mim_1p0=CP
就OK了!
发表于 2012-8-31 10:27:23 | 显示全部楼层
类型画错了,网表上是CP电容,你画的是mim_1p0。网标与原理图不一致,可以让designer重新生成一下网表。
发表于 2012-8-31 10:56:36 | 显示全部楼层
电容类型不匹配,再有就是版图上提取的电容模型好像是三端器件,有衬底;电路上的没有。
回复 支持 0 反对 1
发表于 2012-9-3 11:42:56 | 显示全部楼层
回复 4# liblueice
   请问一下,我和楼主差不多的问题,但用了你的方法怎么不行啊,是不是还有什么地方没注意啊。
发表于 2012-9-5 08:55:44 | 显示全部楼层
我觉得是你lvs rule里面的option没有开对吧,你开了mim_1p0的option ,没有开 cp的,那当然就不认了,去开一下你的option吧~~
发表于 2012-9-5 13:47:44 | 显示全部楼层
*.EQUIV mim_1p0=CP
发表于 2012-9-6 18:04:36 | 显示全部楼层
改正之前,请先确认 cmim等于CP。若不是,就算LVS对了,版图还是错的。
GMT+8, 2025-9-13 08:36 , Processed in 0.020177 second(s), 8 queries , Gzip On, Redis On.
