查看: 4074|回复: 7
[招聘] Marvell 急招 Physical Design
发表于 2012-7-20 16:03:18 | 显示全部楼层 |阅读模式
If you have any interest in the position, please send your bilingual resume as
attachments to  marvell.recruit@gmail.com Subject of your email should be “Your Name_University_Applied Position Title”
Job Title: Physical Design Engineer
Department: COT PD
Requirements:
  -BS/MS in EE/CS required.
-Three or more years of hands-on experience in IC physical design, verification and tapeouts.
-Proven track records of working independently on place-and-route project running and DRC/LVS/ERC/Antenna debugging skills
-Experience with Magma or Synopsys place-and-route tool set and physical design project implementation.
-Knowledge of Mentor's Calibre or Synopsys' Hercules runsets or ruledecks creation and debugging.
-Good programming skill. Capable of writing Tcl or Perl.
-Familiar with synthesis, static timing analysis.
-In-depth understanding of fabrication processing steps used in major fabrication industries.
-Self-motivated team worker, good verbal and written communication skills in English.
-Technical and team leadership proffered. Previous management experience highly desired.
-Experience with synthesis, DFT, and verification is preferred.
Description:
-IC implementation from netlist to gdsii, with floorplanning, place and route, timing closure, and physical verification.
-Crosstalk analysis, power analysis, and static timing analysis.
-Write scripts in Tcl to improve productivity.
-As a key member of central physical design team, your will play a important role in assisting multiple Marvell design groups in physical design, verification (DRC/LVS/ERC/Antenna) and tapeout.
-You will have the opportunity to help develop next generation physical implementation flow for
cutting-edge technology.
 楼主| 发表于 2012-7-23 17:00:42 | 显示全部楼层
回复 1# Hwangbo
    此职位急招中,欢迎投递,我们将会尽快给予反馈! marvell.recruit@gmail.com
发表于 2012-7-24 10:37:04 | 显示全部楼层
慢慢招吧,干这个的人不多。
 楼主| 发表于 2012-7-25 10:34:37 | 显示全部楼层
回复 3# silktree
嘿嘿,所以需要大家帮忙推荐,或者您也可以更新一份简历给到我,以后您有意向了再给您进行推荐。谢谢!
发表于 2012-7-25 15:40:23 | 显示全部楼层
楼主,我是做后端的,招我吧!
 楼主| 发表于 2012-7-26 13:43:54 | 显示全部楼层
好的啊 , 麻烦把简历先发我一份,marvell.recruit@gmail.com。 合适了我会尽快与你联系!谢谢!
发表于 2012-7-26 13:48:56 | 显示全部楼层
前端的可以吗?
发表于 2012-7-26 21:58:49 | 显示全部楼层
同问,前端ok?
GMT+8, 2025-12-22 23:30 , Processed in 0.022130 second(s), 6 queries , Gzip On, Redis On.
