查看: 4172|回复: 5
[求助] 这是什么情况啊,找不到默认的管脚?
发表于 2012-7-10 12:08:41 | 显示全部楼层 |阅读模式
  1. #KL: changed the ordering of the GTP LOCs to match the Board
  2. # PCIe Lanes 0, 1
  3. INST "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[0].GT_i" LOC = GTP_DUAL_X0Y4;
  4. # PCIe Lanes 2, 3
  5. INST "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[2].GT_i" LOC = GTP_DUAL_X0Y3;
  6. # PCIe Lanes 4, 5
  7. INST "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[4].GT_i" LOC = GTP_DUAL_X0Y2;
  8. # PCIe Lanes 6, 7
  9. INST "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[6].GT_i" LOC = GTP_DUAL_X0Y1;
  10.
    复制代码
  1. ERROR:ConstraintSystem:59 - Constraint <INST
  2.    "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[0].GT_i" LOC =
  3.    GTP_DUAL_X0Y4;> [pcie_dma_top_x8_plus.ucf(75)]: INST
  4.    "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[0].GT_i" not found.
  5.    Please verify that:
  6.    1. The specified design element actually exists in the original design.
  7.    2. The specified object is spelled correctly in the constraint source file.
  8. ERROR:ConstraintSystem:59 - Constraint <INST
  9.    "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[2].GT_i" LOC =
  10.    GTP_DUAL_X0Y3;> [pcie_dma_top_x8_plus.ucf(78)]: INST
  11.    "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[2].GT_i" not found.
  12.    Please verify that:
  13.    1. The specified design element actually exists in the original design.
  14.    2. The specified object is spelled correctly in the constraint source file.
  15. ERROR:ConstraintSystem:59 - Constraint <INST
  16.    "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[4].GT_i" LOC =
  17.    GTP_DUAL_X0Y2;> [pcie_dma_top_x8_plus.ucf(81)]: INST
  18.    "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[4].GT_i" not found.
  19.    Please verify that:
  20.    1. The specified design element actually exists in the original design.
  21.    2. The specified object is spelled correctly in the constraint source file.
  22. ERROR:ConstraintSystem:59 - Constraint <INST
  23.    "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[6].GT_i" LOC =
  24.    GTP_DUAL_X0Y1;> [pcie_dma_top_x8_plus.ucf(84)]: INST
  25.    "ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[6].GT_i" not found.
  26.    Please verify that:
  27.    1. The specified design element actually exists in the original design.
  28.    2. The specified object is spelled correctly in the constraint source file.
    复制代码
 楼主| 发表于 2012-7-10 12:12:37 | 显示全部楼层
自己顶一个,有没有人懂 UCF 约束啊, 报错说找不到管脚,我也找不到……
发表于 2012-7-10 14:50:00 | 显示全部楼层
查RTL里有没有这个信号吧?如果没有,直接在UCF里,把这个删掉就好了。
发表于 2012-7-10 15:22:55 | 显示全部楼层
你是直接用的人家的EXAMPLE吧?那里的路径 Constraint <INST
是人家相对于它的设计里写的,你的新设计里面肯定发生了变化,比如顶层,可能就是不ep,你可以在modelsim之类的工具里确认下路径,
 楼主| 发表于 2012-7-10 20:08:59 | 显示全部楼层
   嗯 ,确实是的, 我按照名字改了改名字就好了。
发表于 2012-8-9 15:14:54 | 显示全部楼层
请问"ep/BU2/U0/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[0].GT_i"
这个路径是怎么找的?
GMT+8, 2025-12-6 22:59 , Processed in 0.024154 second(s), 6 queries , Gzip On, Redis On.
